Thread: Broken skimmer basket rim
    The skimmer rim of my pool is chipped in several places such that the skimmer basket is sucked down repeatedly. I don't have any pieces to reconstruct with epoxy. Any suggestions? Thanks
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Broken skimmer basket rim
    Do you have a picture? I would think you could use pool putty to build a new rim, but it's hard to say without seeing it.
    Apr 2014
    Indiana
    4
    Quote Originally Posted by unclescottie View Post
    I had a similar problem with my Hayward skimmer. I just quit using it thinking it was broken and not repairable. Come to find out the ring that the basket sits in is not molded into the assembly and is easily replaceable. I found one in my local Leslie's store for about $10.
    22k gal, IG, Vinyl,Hayward 2hp Super2, SandFilter,
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    This happened to mine this winter (or perhaps a previous winter since this is my first year with this pool). Here's what mine looked like: https://www.dropbox.com/s/yptca04qx7...409_172002.jpg
    Mine seemed to be fixed/glued to the skimmer bucket while the pool guy insisted that they are always free floating and can be replaced. I'd check the pool store/online.
    Have never heard of pool putty. I was going to use white outdoor window/door caulk to repair mine as pool is still winterized/below skimmers.
    Isolated Spa - 345 Gallons
