Results 1 to 16 of 16
Thread: CYA way over 100
    Aug 2013
    Stockton, Ca.
    23
    CYA way over 100
    My CYA test can't be measured because it becomes too cloudy before it reaches any numbers (so its well over 100). MY pool looks fine but I decided to run tests when my regular chlorine test came up off the charts for a few weeks. I had been putting alot of chlorine in it because I was to busy to give it attention. What should I do????
    TC=26.5(FC 26.5; CC=0)
    TA 120
    CH= not needed
    CYA really can't measure cause never reaches numbers on measuring cylinder
    PH 7
    PS the filtration presure is only around 8PSI cause i apparently am sucking in air somewhere.
    Chris M. 20k, inground, defilter, pebbletek, 1hp motor,Tiger Shark QC, TF-100, switched to liquid chlorine 3 years ago LOOOOVVVVEEEE it!
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: CYA way over 100
    You're not going to want to hear this, but you're going to need to do enough drain and refills to get your CYA into a manageable range.
    In order to follow the TFPC method, you need to know your CYA level, and there's no way to accurately test CYA above 100.
    Aug 2013
    Stockton, Ca.
    23
    Thats not a good answer for Calif Boy!! My CYA won't come down when I let up on placing chlorine in the pool?.
    Smykowski's Avatar
    Sep 2011
    3,065
    CYA doesn't break down. It only leaves the pool by removing water (through splashout, backwash, or drain/refill).
    Unfortunately the only way to reduce your CYA is to drain and fill ... although you don't want to drain and fill all at once - it is better to do smaller replacements.
    How are you adding chlorine?
    SwimNPlay AG 15x33 oval 48" high 12k gallons - Used pool set up July 2013
    Hayward sand filter, Sta-Rite 3/4 HP pump
    Kleen Machine Robot, TF-100 test kit
    Central NC
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like the others have said I see a major water replacement in your future, while CYA does break down over time it is at such a slow rate ( a few percent per year) that water replacement or reverse osmosis treatment (available in few parts of the country) are the only ways to lower it in an operating pool.
    Ike
    p.s. you may want to check on the RO treatment option as it is available in some parts of southern California, price though will likely be comparable to water replacement
    Aug 2013
    Stockton, Ca.
    23
    So drain how much?? It was fine last summer??
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Pool Math will tell you how much water needs to be replaced to lower CYA to the desired level.
    http://www.troublefreepool.com/calc.html
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Quote Originally Posted by chrismassod View Post
    You've been chlorinating with pucks and powders, most likely. That's why the CYA climbed.
    http://www.troublefreepool.com/threa...Kit-Directions has detailed instructions for extremely high CYA testing. When you know the actual CYA number, then you can calculate how much needs to go. Reverse Osmosis is really only available around San Diego and Riverside now.
    Aug 2013
    Stockton, Ca.
    23
    How will the extended test measure the cya level when it still only goes to 100?? When mine is obviously over 100?? The directions doesn't tell me what to do after I redo the test with part tap water, e.g. double the value, etc
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    Same boat as you last year - using TFPC to keep up with your water is not possible with astronomical CYA levels (in my opinion) EDIT: wasn't possible for me to do so, I should say
    Did a total refill b/c replaced our liner this year and couldn't be happier - can now finally take of my water like a normal person! FREE from the constant CYA additions thanks to years of horrible pool store advice.
    Good luck !
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I just measured a friends pool @ 160-180 on CYA. I found that the CYA bottle holds approx 15ml to the bottom of the sticker, so I put ~7.5ml of pool water and 7.5ml of tap water, then I added the chemical as normal to obtain that reading.
    I told him he should bring some of his water to my pool after I finish so I can have some of his spare CYA.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    If your CYA level is 90 or higher, repeat the test adjusting the procedure as follows:
    Fill the mixing bottle to the lower mark with pool water.
    Continue filling the mixing bottle to the upper mark with tap water.
    Shake briefly to mix.
    Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark.
    Continue the test normally from step 3, but multiply the final result by two.
    This is cut and paste from the extended directions, are you saying that after diluting with tap water you still get over 100? (doubled that would be 200+ if I understand those directions correctly) You may be waayy over... I think I've read here of people diluting even more, but I don't know the specifics. No matter what you're going to have to replace water.
    And again, I'll step back to let the experts chime in.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Oct 2013
    Chapin, SC
    1,141
    Yes, I had to dilute mine 3 times to get the reading to be below 100 had to multiply it by 8 to get a 320 ppm This was when Leslies was telling my my CYA was 40 for about 5 samples
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Richard320's Avatar
    Jan 2010
    19,023
    Well then, try this:
    put one part pool water and two parts tap water together and mix. It doesn't matter how much of each, as long as you're precise. Use a measuring spoon or something if you don't have a graduated cylinder. Then use that diluted sample to fill the CYA mixing bottle to the line. Then fill the rest of the way with the reagent and mix. Take several readings, pouring the solution back into the mixing bottle and repeating it until you're content with the number. Triple it. You'll probably be +/- 20, but it's close enough to calculate how much you need to drain off.
    Have you been chlorinating with pucks and pwders?
    Aug 2013
    Stockton, Ca.
    23
    Pucks
