Thread: Alternative to Jack's and Metal Magic? HTH Metal Control
    Apr 2014
    Indiana
    106
    Being able to find neither of the recommended sequestriants in town (Jack's Pink Stuff or Metal Magic) I ordered some online. My Ascorbic Acid will be here today and I haven't heard where my Jack's currently is. I'm a very impatient person and want to start the treatment ASAP, but don't want to start without it.
    As I was walking through Walmart to buy a nice, large measuring cup for chemicals I happened on the pool section so I stopped in to see if they had calcium (they didn't) but I did see they had HTH Metal Control. It's Hydroxyethylidene Diphosphonic Acid and it only about $16/quart. Has anyone got an opinion about it? It would be nice to not have to buy from online if I need some quickly.
    Re: Alternative to Jack's and Metal Magic? HTH Metal Control
    HTH Metal Control is good, similar to Jack's and less expensive.
    Apr 2014
    Indiana
    106
    Quote Originally Posted by JasonLion View Post
    Hmm... Should that be noted in the Pool School article about staining (http://www.troublefreepool.com/conte...d-metal-stains) since it is easily found at Walmart (all locations?) whereas the recommended chemicals can be hard to come by, locally?
    Thanks for the recommendation! If my Jack's isn't here tonight at least I know I can go ahead and get some from Walmart and use the Jack's for continued maintenance when it gets here.
