Thread: to much anti algae
    Apr 2014
    duras,s.w.france
    2
    to much anti algae
    hello,brand new to the forum,so hello!. just came back from a week away to the uk(l live in sw france),only to find the person who house sat for us has been over enthusiastic whith the anti algae liquid,resulting in that every time the pump runs,a large amount of foam covers the surface of the water.ive tried runnng the pump for 48 hours,backwashed many times,tried scooping the froth off wth a fine net,all to no avail!.panic,as we have paying guests arriving this week in our rental gite-HELP! any ideas how to get rid of this foam!
    30,424
    Re: to much anti algae
    Chlorine up to around 10 ppm will be the best way but it may take a day or more. Run your pump 24/7.
    Can you test your water and report results?
    Butterfly's Avatar
    South Carolina
    10,045
    Having a full set of test results will help us help you.
    Raising the FC level above target level (based on FC/CYA chart) will help kill the foaming.
    If you have metals or used a copper-based algaecide, a sequesterant is recommended.
    Welcome to the forum!
    You're done SLAMing when:
    Apr 2014
    duras,s.w.france
    2
    hi, thanks for info,will start upping the fc level tommorow,will let you know how i get on,again,many thanks
