The best way to heat my pool?
Jul 2, 2008
1
Hi, I need some help. One person I spoke with said that the best way is a heat pump, the next says a propane gas heater. One person says I need 115,000 BTU the other says 400,000 btu. My pool is inground 18X36. Can anyone help me?
Thanks, Richard
How do you want to use it? A big gas heater will warm the water quickly if you only use it on weekends. A heat pump takes longer to warm the water, but is usually cheaper to operate than gas. If you have the roof space, solar is nice, even if only to supplement a fueled heater.
I would suggest seriously looking at a solar system. I have an above ground pool but they work for in ground as well. I only installed my solar system a few months ago. I did not put much faith in it working too well. Well let me tell you how wrong I was. I am so impressed with its performance I will never be without a solar system again, no matter how big or small a pool I have. If the system is sized properly you will get more heat than you can use.
I installed 2 2x20 sungrabber panels on my south facing roof. The panels are 50 feet from the filter and 14 feet high. I plumbed it in 1 1/2" pvc with a manual bypass kit. After I initially turned everything on and made sure I did not have too much back pressure, about 2-3 pounds, I took the floating thermometer and placed it in the return stream. The water returning to the poll was 2 degrees higher than the water itself. This temp increase was sustained. About 2 hours later I found a few leaks in one panel, damaged. I have only been running 1 panel since, waiting on the warranty replacement. I have had the pool up to 92 degrees after 3 good sunny days. I keep a solar cover on when no one is in the pool to help retain the heat.
Oh, did I mention it costs nothing to run. Can't beat the price of free heat.
I love my solar panels!!!!!!!!!!!!!!!!!1
What Macrosill said!!!
I use Solar only to heat our pool and with sun on the panels all day(9:00 am - 6:30 pm) our pool will heat from 80* to 90* with the cover on most of the day. Our pool is in the shade from about 2:00 pm on. Details for the solar are in my sig.
HTH,
Adam
Ditto on solar. NY here, I keep my temps in the high 80's with solar only, could go into the 90s if I wanted to. With the price of electricity & propane only going UP, investing in solar now makes sense (if you have the space).
