Thread: Volume of posts on TFP
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I try to read or skim every post on TFP via the unread posts option. It takes a lot of work to keep up with.
    I was just curious of the average number of posts per day or month or whatever. Does the forum admin/mods have any stats on this?
    Billy
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    38,272
    Re: Volume of posts on TFP
    It will probably triple the coming weeks then slow down slightly for a little while then ramp up when peoples pools turn green at the end of summer, then people are trying close, then it gets slower until the Australians show up
    I know there is some data, but the new forum software since January is a bit different. Not sure if there true stats going back years though.
    There were 150 posts yesterday. In june it will be ten or twenty times that many a day.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yup, you guys are going hard into summer, and we're coming into freezing down here.... lol.... I'll be opening my pool in October this year... Sounds weird doesn't it??? lol
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Casey's Avatar
    SW PA
    10,432
    It is weird Lacey! I couldn't imagine having Christmas in the hot summer time heat! Just weird because it never happens for me at least, living in PA!
