Thread: Plugging a pipe ID
    Rocklin, Ca
    467
    Plugging a pipe ID
    The plumbing to my under construction pool was under pressure and leak free for more than a week. The PB cut the cap off the waterfall line when the waterfall was built a couple of weeks ago.
    My concrete guy has been working around the pool for the last week setting forms and building a retaining wall. The concrete guy and I had a long discussion where I showed him pictures of the exposed plumbing and we walked all around the yard so I could physically show him where the pipes are.
    Since the forms are nearly finished I want to put the system back under pressure to see if something has been damaged while he was working. The concrete guy wants to cap off the waterfall line at the equipment pad and then pressurize the remainder of the system. This will forever leave a question mark about the integrity of the waterfall line, however, I suppose a small leak in the waterfall line would not be the end of the world since it is not be ran too often.
    Is there a non destructive and temporary method to plug the ID of the waterfall line at the waterfall? I'm envisioning some kind inflatable bag.
    Kevin
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Plugging a pipe ID
    There are inflatable plugs that plumbers use when they can't shut the water off to a line they need to work on, but it sounds like you just need a test plug.
    Mar 2008
    League City, TX
    144
    This is what they used when testing the plumbing when our house was built.
    http://webstore.petersenresources.com/5.aspx
    Pool completed in the fall of 2008.
    Landmark's pool build
    Freeform 26' x 45' IG gunite, 4' to 8' deep, 29,500 gallons, WetEdge PearlMatrix Tropical Mystic, Freeform 8' X 11' Ultimate 16 jet spa, 38' moss rock weeping wall and 3 waterfalls,
    4 pumps (Intelliflo 4X160 filter pump, WhisperFlo 3HP spa pump, Pentair 2 1/2HP WaterFall pump, cleaner booster), EasyTouch 8 controls, Quad DE 100 filter, MasterTemp 400K heater, Pentair Legend Platinum cleaner, 995 sqft. Sundek.
    Rocklin, Ca
    467
    Thanks
    That's exactly what I was looking for.
