Results 1 to 13 of 13
Thread: Need a new pump
    Apr 2013
    Southern California
    29
    Need a new pump
    Split off of here. Please ask questions in your own topic, rather than hijacking someone else's existing topic. JasonLion
    The Original Poster and I have the SAME exact pool and motor specs not to mention the situation. I also cant wrap my head around downsizing to a 3/4. Was looking at the Whisperflo 011772 1HP
    17000 gl. In-ground vinyl pool
    Naturesoft/aquarite SWG t-15 cell
    Vinyl liner measured and installed by me
    Re: Pump Selection Help
    jdfrye, you can save a lot of money by getting a two speed and running it on low speed. Also, WhisperFlo pumps are quite large compared to their listed HP. You are much better off with something like the SuperFlo, which is smaller (despite the having the same listed HP). All assuming you don't have a spa or waterfall or other obvious water feature.
    Smaller pumps are more efficient. A two speed on low will save around 50% on electricity.
    Apr 2013
    Southern California
    29
    Sorry for the HiJacking I seem to do that in real life also.
    I like that you gave me a name for the superflo, now should i get the 3/4 or 1hp?
    and do you have a name for the two speed pump you suggested? That way I can look into it. it might be also good that I could switch to high when I add a 30 foot hose for vacuuming.
    38,303
    Re: Need a new pump
    There are 2 speed versions of the Superflo. It is difficult to find the ¾HP which is 115 volt, but the 1HP which is 230v is usually a good choice.
    Apr 2013
    Southern California
    29
    Re: Need a new pump
    Would the Pentair superflo 340042 - 2 speed 1 HP pump be what I'm looking for?
    38,303
    Re: Need a new pump
    That is what I have. Comes with union fittings and manual speed selection switch.
    Apr 2013
    Southern California
    29
    Re: Need a new pump
    Oh YEah! we have confirmation from a Pro!
    Oh, Lizzle! I love your Andy Avatar going for the freestyle win. my kinda style
    Thanks Jason and JB!
    Jul 2013
    Waxahachie, Tx.
    446
    Re: Need a new pump
    I have a Hayward variable speed. At 1500 rpm which is half speed it draws only 194 watts.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Apr 2013
    Southern California
    29
    Re: Need a new pump
    Installed the pump and I'm amazed at how quiet it is. I'm running it at low and wonder how much energy I'm using? I know That I'm paying .10 -.18 cents KWH. what is the formula for this pump to figure how much it costs to run for an hour at half speed and full speed? Do I need to know what the watts are like the poster above me?
    38,303
    Re: Need a new pump
    The trick is to figure out the watts as that is your cost. But, it is not straight forward to figure out as it is a function of the head loss in your specific pool.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Need a new pump
    To know what you are drawing you would need an electrical clamp meter as the load on an electrical motor will vary the amount of power it draws and load will vary some depending on your plumbing.
    Ike
    Apr 2013
    Southern California
    29
    Re: Need a new pump
    Bahhhh! Shucks! to hard to figure.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Need a new pump
    Your plumbing is probably close to "curve a," which is supposed to be for typical 1-1/2" plumbing. For curve a, the pump database has the following data for the 1hp two speed Superflo pump:
    High Speed: 3450 rpm, 56 gpm, 1378 watts
    Low speed: 1725 rpm, 31 gpm, 322 watts
    An hour at high speed will cost you in the neighborhood of 14 to 25 cents
    An hour at low speed will cost you in the neighborhood of 3 to 6 cents.
    That is based on 10 to 18 cents per kWh.
    The exact numbers would change depending on your plumbing's resistance to flow, but these are probably good enough to get a rough idea of costs.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
