Results 1 to 8 of 8
Thread: Checking in
    Mar 2014
    Edmond, OK
    17
    Checking in
    Hi. Y'all were so helpful to us as we were getting set up. I wanted to post again with our weekly test results. They've been pretty consistent the last 2-3 week.
    FC 2.5, CC 0.5, TC 3.0
    CH 400
    TA 170
    CYA 35 (down just this week, had been holding steady at 40)
    pH 7.8 (our well water is slightly alkaline and tests at about 7.2-7.4)
    How do these numbers look? And how often should I expect to be adding bleach to the pool? Is there a frequency that would be concerning, or is it just, do it as needed and keep TC in the right range?
    Thanks so much!
    Natalie
    Supercal
    18,000 gallons, above ground pool, vinyl liner. Swim Pro SW256T Sand Filter, 80GPM, 35 GMP/ftsq
    More than 3 years old
    Well water
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Checking in
    More chlorine!! Everything else looks fine, but with a CYA of 35, you should never let your FC get below 3. I'm conservative, so if I were you, when the FC gets to 4, add more so it goes to 6. It's important, so I'll say it again....never let the FC get below 3.
    Plan on adding bleach every day until you get the feel for your pool.
    Did I mention that you should do whatever is necessary to keep your FC above 3 at all times?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Checking in
    It's all right here. Saves me some typing.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Checking in
    Richard,
    Unless I'm missing something, did you post the wrong link?
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    Richard320's Avatar
    Jan 2010
    19,067
    Re: Checking in
    That's the basic schedule. You asked how often you should be chlorinating.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,110
    Re: Checking in
    Natalie,
    Even though this thread is a few day's old, I'm not sure that all your questions have been clearly answered. As Smykowski stated, you're low FC level is putting you at risk for algae to form in your pool. Keep your chlorine levels above 3 at all times. I'd personally suggest at this point aiming for a 5ppm level. This allows for some normal FC lose, however will always keep you above the 3ppm level. You should be testing your chlorine and pH levels daily and adjusting as needed.
    How does your water look?? Can you post a photo???
    WELCOME TO TFP!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Checking in
    As Leebo said...at least the FC and Ph should turn into "daily" test numbers instead of weekly until you get a feel for what your pool requires. Summer heat changes everything!
    Mar 2014
    Edmond, OK
    17
    Re: Checking in
    We do test the chlorine and pH daily, I merely posted the weekly numbers because they have been pretty consistent. Thank you for the chlorine advice. I raised it to 6 and will aim to keep it in the 5-6 range on a daily basis. Our water is clear, though we continue to have issues with stuff on the bottom of the pool, but our property has a lot of trees, so this may just be a constant battle for us. I will post a picture later today.
    Supercal
    Well water
