Results 1 to 7 of 7
Thread: Cartridge Filter
    Apr 2014
    illinois
    3
    Cartridge Filter
    13.5K AG Pool, 2 hp pump, looking to switch from sand to cartridge filter. Recommended size? Brand?
    Re: Cartridge Filter
    I recommend getting an oversized filter. Larger filters let you go longer between filter cleanings. Perhaps a 350 sq ft.
    Apr 2014
    illinois
    3
    What is the minimum size? I just want to make sure not to go too small.
    38,472
    I would not go smaller than 200 sqft for your size pool ... I think 350 might be a bit larger than you need, but it does not hurt anything. Although, you have a pretty large pump and likely high flow rates, so bigger might be better.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I've read it several times here from other experts: For cart filters, get the largest you can afford. No one who has followed that has ever posted "I should have gotten a smaller filter".
    Apr 2014
    illinois
    3
    Thanks!
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    This is what I have for my pool, which is about the same size as yours. It is a 325 sq ft filter. I felt that it was a good price point. Jumping up to the next size is a lot more expensive. I could have gone smaller, but like Charlie said, "get the largest you can afford." Pentair makes similar filters. I don't think the brand matters, but there have been negative reviews of the Sta-Rite System 3.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
