Results 1 to 10 of 10
Thread: Question about DE safety
    I just got a brand new hayward De4820 filter, and my wife and I were discussing DE - specifically the fact that there's food grade, and pool grade - and pool grade is known to be hazardous if ingested.
    Her concern of course was that if it's hazardous when ingested, what happens if some of the DE is in the pool that people are swimming in? Does that DE in the water not irritate skin, eyes, etc and cause problems if water is swallowed? I know the reality is thatthere would be a ridiculously small concentration in the water if I use 6 lbs in my filter for a 12-15k gallon pool, but still, she's kind of an anxious person once she has an idea in her head, and Im not finding much info online about pool grade DE to put her at ease.
    Also, I did see "fiber" mentioned in another theead, it seemed as an alternative to DE... does anyone know much about this? Is this simply a different media that can be used in "DE" filters?
    Appx 15,000 gallon (odd shape) IG Plaster, Hayward DE4820 DE filter, Hayward TriStar 1.58Bhp/1.0FRHp
    Pool built by previous owner, home purchased 11/2013
    Houston, TX - 2 dogs - Palm Trees
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Question about DE safety
    DE is an inhalation hazard. It has microscopically sharp particles, like asbestos, that scar the lungs. Try "inhalation" in the search box and you'll find plenty of threads, and probably some good links to read. It isn't dangerous when it's wetted.
    The replacement fiber is highly processed cellulose. Wood pulp. It's even used in food. It's very light and fluffy, and probably isn't good to inhale, either, but it's just superfine sawdust. It strongly resembles blown-in insulation. I use it. It filters well and I backwash onto the front lawn and the stuff just rots away since it's biodegradable. DE will pile up wherever its backwashed and then there's that dust problem again. If you search "fiberclear" you'll find some threads that discuss it.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've just switched to FiberClear in my DE filter. The reason for the switch is I just wanted to try it out.
    The thing with DE is you don't want to breath it in. When I charged my filter with it I made a slurry out of it and then slowly poured it in the skimmer. The only why you should get it in the pool is if you have a tear in one of the grids.
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    My understanding is that the risk of the DE is of concern with the lungs. You arent supposed to breath it as you pour it into the skimmer (or any other time for that matter). I would suspect any DE in the water that made it's way into your lungs would be of secondary importance if that were to happen, since you would have inhaled water along with it and in fact likely be drowning, or on the verge of it.
    To my knowledge, there is no danger of it to the digestive tract if diluted in pool water.
    Some of the other folks here have used the fibers. Im sure some will chime in soon.
    Divin Dave,
    There should be no DE in the water. When you add DE to the skimmers, watch the returns closely for about two minutes. Any DE getting past the filter will be visible as it comes out of the returns. Even if some gets in the water, it's not any sort of hazard. The fiber substitute is a good alternative if you don't want to use DE.
    Support the site
    Aug 2011
    Southern California
    188
    How much of this product do you use in a DE filter? I have a 60 sqft Pentair and not sure what amount of the fiber it would take to coat this unit.
    Usually the same volume as the correct amount of DE.
    Support the site
    Aug 2011
    Southern California
    188
    Quote Originally Posted by JamesW View Post
    Seriously? DE called for about 8-9 one pound coffee can scoops. I hope fiber isn't that much?
    DE has a bulk density of about 48 ounces (volume) per pound. If a filter requires 6 pounds of DE, you would use about 9 quarts of DE or fiber.
    The fiber is less dense, and therefore, the weight will be less but the volume will be the same.
    Also, the bag of fiber has a chart showing the proper amount of fiber per square foot of filter area.
    Edit- FiberClear says (2.5) 9 oz bags for a 60 square foot filter. Jacks Magic Filter Fiber Stuff says (5) 1 lb DE scoops for 60 square feet.
    Support the site
    Richard320's Avatar
    Jan 2010
    19,034
    Usually the bags have a scoop in them and a chart that tells you how much to use printed right on it. I use the kitchen scale, myself.
