Results 1 to 14 of 14
Thread: Patio build
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Patio build
    Pictures of progress from Thursday through yesterday
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    Re: Patio build
    Nicely done. What's next?
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Patio build
    Fixing my pool leak and more patio
    TF100 test kit
    Re: Patio build
    And, um, SLAM the pool?
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Patio build
    yes I was starting to SLAM until i noticed it leaking water. So much work
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    construction update
    Merged to keep on topic of previous thread made. Casey~
    As part of the patio build with pavers I am also rerunning my electrical from garage to pump and installing solar plumbing runs. The 50' long trench is dug from garage to pump and i will be burying 2 runs of 2" wide schedule 40 for the solar and 1" PVC for electrical.
    I had electrical out at the pump already but it came directly from the house and the breaker box and timer were a mess and rusted. The original connection was done in 1971 and I have no idea what condition wire is in. I do know it works. My electrician, whom is not getting paid as what are friends for, said since we are running wiring to the garage it makes sence to put the timer and breaker box in there and then run a line to pump from garage. It is more work but seems to make sence.
    TF100 test kit
    38,322
    Re: construction update
    I think I disagree. I would put a new sub-panel by the pool equipment and keep the timer out there as well. In fact, by code I think you have to have a disconnect within sight of the pump.
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    thanks jbizzle, i will bring that up
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Patio build
    More updates decided to build a stone retaining wall with all my rocks
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Patio build
    Updated pictures. A lot of brick will be put down this weekend if the rain holds off
    TF100 test kit
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,820
    Re: Patio build
    Did you put landscape fabric up behind the rock retaining wall to keep dirt from migrating through? I do think you could skip drainage lines behind a wall that size as it looks like you did, especially because the water will drain right through.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Patio build
    More progress
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Patio build
    More pictures
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Patio build
    Painted the faded old blue concrete. Looks better now
    TF100 test kit
