Thread: Pool returns.....matter which direction?
    Apr 2014
    Vancouver Island
    14
    Hi everyone.....Happy Easter. Brand new here and 2nd season as a pool owner. Wondered if there was an optimum angle to circulate, particularily for solar heat. I have two returns - thought maybe down to heat the deeper water?
    Thanks
    Re: Pool returns.....matter which direction?
    Welcome to TFP!
    You want to aim the returns to create a consistent water motion, usually in a circle around the pool. One return should be aimed down and to the side so it sends water towards the bottom of the deep end and also supports the circular movement. That will promote mixing with the deeper water. The other should be just towards the side. Fiddle with them until you get a consistent movement that drives debris into the simmer (even if slowly).
    Smykowski's Avatar
    Sep 2011
    3,065
    Welcome!
    It's gonna be trial and error. Mixing up and warming the deep end vs strong skimming action on top. In your situation, I'm not sure that there's a wrong way to do it.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If it helps, what I do with mine is one pointed down and to the side a bit, the other pointed to where it helps the prevailing wind drive surface crud to the skimmer.
    Apr 2014
    Vancouver Island
    14
    Awesome. Thanks for the tips!
    13,000 gallon 17x40
    Pentair Tagleus TA50 2011
    Hayward Max Flo XL 1hp 2014
    Enersol Solar
    Vancouver Island BC Hydro rate avg .10 kW
