Thread: sodium or calcium hypochlorite
    guys,
    I am looking to supplement the tablets I am using in my 17000 gallon pool.
    I am using liquid chlorine with is 12.5% sodium H/C.
    I am wondering if a 1lb packet of shock containing 68% calcium H/C is cheaper/ more conventient and will add more chlorine to my pool. I think 1 packet would be enough just to supplement my chlorine.
    Thoughts ?
    or do I have this wrong and should be comparing liquid chlorine to Concentrated Chlorinating Granules . If that is the case am I getting more for my money with granule over liquid chlorine
    May 2013
    mid-TN
    102
    Re: sodium or calcium hypochlorite
    did you read the BBB method yet?
    http://www.troublefreepool.com/threa...-for-Beginners
    the reason for the BBB method is tablets usually puts in too much CYA and it could take a lot of
    chlorine to shock.
    if CYA is low enough just a small amount of chlorine is needed to shock the pool.
    18X36 Grecian 24400 est., pacfab sand Triton II, 1.5hp AOSmith, clormatic 2
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    If your pool needs additional Calcium or Cyanuric Acid, then Cal-hypo or dichlor might be an economical solution. Without knowing your test results, there's no way to tell. Maybe you're already too high on CYA or CH? You could end up making a bad situation worse, which is no saving at all.
    This article in Pool School will explain the advantage and disadvantages of the various forms of chlorine.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Without information on the cost of each source of chlorine, we can't answer that. Other factors also come into play, such as your current CYA & CH levels and what type of pool surface you have.
    How to Chlorinate your Pool in Pool School explains each source of Chlorine.
    --EDIT: Richard beat me to it!
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Smykowski's Avatar
    Sep 2011
    3,065
    Chlorine is chlorine is chlorine. Depends the unit cost and if you want the byproducts in your pool or not.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    This would really help us answer your question. All forms of chlorine will sanitize the pool. The determining factor as to which form of chlorine is best for you starts with determining the current CYA and CH levels of your pool water.
