Thread: CYA test illumination
    Apr 2013
    Dallas, TX
    59
    I know you're supposed to do it in full sunlight, with your back to the sun and held at waist level, but one thing I was wondering the other day, should the tube be in the shadow of your body or be illuminated by the sun? Also, you mention holding it differently changes things - what's the best way to hold it?
    ~15k gal IG pebble pool/spa w/ water features, Goldline ProLogic + SWG, 2x Hayward Northstar pumps, Hayward Booster Pump, Hayward 60sqft DE filter, 400k BTU Hayward heater, Hayward Viio Turbo pool cleaner, TF100 test kit
    38,515
    Re: High cya level
    It should be in your shadow. I hold it with 2 fingers at the top of the tube.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: CYA test illumination
    The important thing s that it be very bright yet not have the sun reflecting off the surface in the view tube. I do it on the patio so there's all that light reflecting off the concrete and I hold it at the very top with just thumb and forefinger.
    Just keep pouring it back into the mixing bottle and repeating it.
    GoGrabTheNet's Avatar
    Dec 2015
    Phoenix, AZ
    64
    Bumping this old thread to check in to see if anyone has a more "controlled" method of checking the tube. If I perform the test in my kitchen which has nice-and-bright recessed light fixtures, then I get very close to, if not the same reading, compared to when I do it in sunlight.
    13k Gal. PebbleTec IG pool : Pentair IntelliFlo VS pump : Hayward 8-cartridge filter system : A&A in-floor cleaners : Jandy 115k BTU heat-pump : A&A auto-filler : Stenner 45MPHP10 auto-chlorine feeder : BBB Method
