Results 1 to 14 of 14
Thread: Vinyl Pool CH?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Vinyl Pool CH?
    Is there such a thing as too low of CH for a vinyl pool? I ask because my fill water (well) CH is down to 20 ppm (it varies depending on season, droughts, etc. but is always below about 70 ppm). Looking for your thoughts, not just reciting numbers from pool school, etc.
    Ike
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Vinyl Pool CH?
    Not really, but you can read more about this in the thread Did you know that Vinyl liners contain calcium? You can skip to the last post if you want where not saturating the water with calcium carbonate might be a problem for vinyl liners that contain high amounts of calcium carbonate (> 20%) since such vinyl liners were susceptible to chemicals including chlorine and acid while liners containing low amounts (< 7%) did not have such problems. We've got lots of vinyl liner pools on this forum and never had any reports of issues due to low CH and at least a few pools reported very low CH (one had literally zero, if I recall).
    Re: Vinyl Pool CH?
    I had a similar question. My CH is only measuring 80 and I wonder if I should leave it alone or raise it ... I thought I read that for vinyl pools you need to test to make sure it isn't too high, but not sure about when it is lower than the recommended amount.
    SwimNPlay AG 15x33 oval 48" high 12k gallons - Used pool set up July 2013
    Hayward sand filter, Sta-Rite 3/4 HP pump
    Kleen Machine Robot, TF-100 test kit
    Central NC
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Vinyl Pool CH?
    Mine averages about 50 over the last 5 seasons........no apparent issues.
    Re: Vinyl Pool CH?
    Our recommended CH level for a vinyl pool is 0-300, so you are comfortably in range.
    Re: Vinyl Pool CH?
    Ok ... I see the 0 now ... that's what I get for looking at numbers before my 2nd cup of coffee!
    Central NC
    Jul 2011
    NY
    51
    Re: Vinyl Pool CH?
    If you have fiberglass steps in your vinyl liner pool you likely want to maintain your CH. I have run into blistering on my fiberglass steps due to insufficient CH.
    29,700 Gallon Vinyl Roman End, Sta-Rite Max-Therm-400HD gas heater, Sta-Rite S7M120 cartridge filter, Pool Pilot DIG-220 SWG
    Re: Vinyl Pool CH?
    bumpy, what do you keep your CH at? Opening our pool now and staring at those darned blistered steps, would like to at least slow down development of more.
    19x43 Inground Vinyl Pool, approx 22 years old, no main drain, 2 (lopsided!) skimmers, 2 returns.
    1 HP Pentair Superflow Pump
    27" Hayward Sand Filter
    AutoPilot SWCG
    Aquabot T-4 Cleaner
    30,432
    Re: Vinyl Pool CH?
    I am not aware of blistering in an FG that can be attributed to low CH.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    Re: Vinyl Pool CH?
    How old were the steps before you started seeing any changes to the steps.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: Vinyl Pool CH?
    I'm at 80 too, and am just leaving it alone.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Re: Vinyl Pool CH?
    Our pool was put in around 1988 I believe, we've only owned it for the last 4 years and you could see the blisters with surface cracks since we've been here - though they appear to have gotten worse over the last couple of years. I believe we've kept the water pretty well balanced since we've had the pool, though we did convert to a SWCG - which I wouldn't think would have contributed to this issue. So I don't know if we've caused them to look worse or it's just been the timing. The first year we had the pool, didn't know anything about pools, had a pool company come out to show us the opening procedure. They handed me a bottle of test strips and told me to only worry about three of the four (told me stabilizer wasn't important). I later found this site and bought a real test kit. Apparently the stabilizer wasn't important because it was off the charts. The previous owner had been using tablets and apparently didn't monitor CYA either. I found TFP sometime in the first year of ownership and feel like the water balance has been pretty good since then. Feel like the chlorine and CYA had been high for several years before and have no idea if pH was monitored before we bought the house.
    It's my understanding that the staining in the surface cracks is caused by cobalt leaching out of the layer under the finish layer on the steps. Tested calcium yesterday and we're at about 90. Not really sure calcium is part of the problem, but am going to do a little more research. Was interested if bumpy was having any luck slowing down his blistering by altering his calcium levels.
    AutoPilot SWCG
    Aquabot T-4 Cleaner
    Jul 2011
    NY
    51
    Re: Vinyl Pool CH?
    Sorry guys .. just catching up ...
    Here's an earlier thread on the matter at hand. It's worth a read through. Perhaps CSI may be the metric to look at: http://www.troublefreepool.com/threa...442#post534442
    Re: Did low calcium cause my fiberglass steps to blister?
    As far as we know CSI has no relationship with fiberglass. The only confirmed effect is that CH below 200 with fiberglass seems to make metal staining more common/worse than it otherwise would be. And there remains the one engineer claiming it was important to prevent cobalt from being leached from the gelcoat, though how that might work no one can figure out.
