Thread: intex questions
    intex questions
    Hey guys ive got an intex 16ft ultra frame im wanting upgrade the pluming to pvc and do a tru the wall skimmer and add a second return fountain. iv got an intex sand pump and an intex salt water system anyone have any pis with these 2 pumps hard piped? Ive searched for some pics but no luck. Size pvc is 1 1/4 right?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: intex questions
    There used to be a couple of threads showing how to make adapters......Here's one, with pics.
    Most of us who are doing the hard plumb are using 1-1/2" PVC.
    For your suction lines, you could even go 2", if you have long runs to your pump. My own experience is that 1-1/2" is quite adequate for both suction and return. I've put two returns on my pool, and get a fairly quick moving whirlpool in a very short time.
    Casey's Avatar
    SW PA
    10,428
    Re: intex questions
    Here is another with a few skimmer pics....
    http://www.troublefreepool.com/threa...Intex-Confused!!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: intex questions
    Ah, Casey beat me to it...
    That's the best thread... Its the one I'll use as a reference before I cut my pool liner....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
