Thread: Just Opened, High Water Level
    Apr 2014
    Syracuse, NY
    1
    My local pool company just opened my IG pool and I noticed that my water level is too high, above the skimmer. Is it ok to drain the pool so soon after they added chemicals? They added: Chlorine, "clarifier" (not sure exactly what it was, CYA, and salt (I have a SWG)
    Thanks for the help?
    Re: Just Opened, High Water Level
    Welcome to TFP!
    Sure, it is fine to drain a little water right now. Just keep an eye on it and don't drain too much
    Mar 2014
    Las Vegas
    288
    A pool company that went ahead and added chemicals when there was a obvious problem (high water). I don't think I would be using that company again. They should have fixed the problem before adding chemicals. Just my opinion.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
