Results 1 to 12 of 12
Thread: How much chlorine/oxidizer to use after soak?
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    This is a great forum. I am so pleased I found this site as well as poolspaforum.
    I've been following waterbear's bromine for beginners at both sites. It has left me with a few questions. One of which is how much, if any, oxidizer/chlorine do I use after a soak? I have a 300 gallon spa for which I am using bromine following the three step process.
    Thanks for any help.
    Madison Mike's Avatar
    Apr 2014
    Columbus, WI
    31
    Re: How much chlorine/oxidizer to use after soak?
    I believe chem geek already answered your question on the other forum. There is no definite answer like 1+1=2. Adding oxidizer after a soak has so many variables to consider that giving one answer doesn't work. Two adults who bath in the nude with a shower before the hot tub will give a different result than 2 teenage girls with swimming suits and makeup on. Your test kit will tell you what to add before and after your soak.
    I guess it would be neat if Pool Math had an "if then" formula at the bottom for this topic. For instance, plug in 2 bathers, nude, 30 minute soak, then add this much oxidizer. Wouldn't be perfect, but I'm sure it would get you in the ballpark.
    Jacuzzi J375 Spa, 415 gallons, Bromine Sanitizer
    Mar 2007
    San Rafael, CA USA
    12,082
    The rough rule-of-thumb that applies for soaking in a hot (104F) spa that has no ozonator is that every person-hour of soaking needs roughly 3-1/2 teaspoons of Dichlor or 5 fluid ounces of 6% bleach (3-1/2 fluid ounces of 8.25% bleach) or 7 teaspoons of non-chlorine shock (43% MPS) to oxidize bather waste. With an ozonator, the amounts could be roughly cut in half. These quantities are independent of spa size and are the same regardless of whether you use chlorine or are activating bromine from a bromide bank.
    For bromine, you add whatever amount is needed after a soak so that you still have a residual after 24 hours. The rule-of-thumb above is just that, a rule-of-thumb, and people sweat somewhat different amounts. In between soaks, bromine tabs can maintain a residual bromine level. If you have an ozonator, then it may be able to maintain a residual from the bromide bank, possibly enough to not need bromine tabs.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Tx for the replies. It is very appreciated.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    On a related note, anyone know how much 8.25% bleach to use for my weekly spa shock? I just picked up a 3 pack at Costco. Waterbear's post states that for a 250-300 gal spa shocked with 6% bleach, a person needs 3/4 cup. If u could enlighten me that would be great.
    Mar 2007
    San Rafael, CA USA
    12,082
    You would just scale it so 3/4 * (6/8.25) = 0.55 so roughly 1/2 cup of 8.25% bleach should be fine. That's around 9 ppm FC in 300 gallons.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Tx a bunch for the quick response!
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    One thing I have noticed is that bathers come in different sizes, and the amount of chlorine required after a soak definitely scales with the size of the bather. There's probably a smartphone app that analyzes a picture of the bathers and gives you a recommended chlorine dose, but I haven't found it yet
    Worst case bather load (hunting buddies & tub too hot) seems to consume about 16 oz of 10.5% bleach for 3 bather-hours before leaving me with a few ppm of FC. I generally add 8 oz, wait a few hours then add the other 8 oz, but IIRC the initial reaction (to monochloramine ?) is pretty fast so I guess waiting only a half hour (or dumping it all in at once) might be better.
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Apr 2014
    Columbus, WI
    31
    bridgman, so you are saying that your hunting buddies are eating up too much chlorine? Aren't they bathing in no scent soap, shampoo, and using scent blocker clothing to shoot da thirdy pointer? LOL. Your tub picture looks great!
    Mar 2007
    San Rafael, CA USA
    12,082
    The rough rule-of-thumb is 5 fluid ounces of 6% bleach per person-hour so for 10.5% bleach and 3 bather-hours this would be around 8.6 fluid ounces so somewhat more than half what you are using. Big sweaty hunting buddies -- have to note that increases chlorine demand
    It's not a problem for you to add the entire chlorine amount at once rather than in doses. It will just have the reactions go faster but you'd want to keep the cover off to outgas some of the chloramines. I also presume you have no ozonator, otherwise the chlorine demand from bather load would likely be less, though the chlorine demand in between soaks would be higher.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    I noted the yellow caution at the top of this thread before posting this, but since this was my original thread/post, I can proceed fwd. Not to mention, this next question is related.
    Regarding the post-soak addition of sanitizer (not the weekly shock), if I use my spa 2x in one day (more than just 1x), do I still add after each soak, or do you TFPers add at the end of the day or when it will not be used anymore that day? For instance, I just used it w/ my kids. My spa is bromine sanitized. I added my Dichlor accordingly after our soak (2 tsp). I use Dichlor b/c I think it is the easiest since I can leave that next to the spa w/ a measuring tsp. vs. chlorine which I would have to walk to the garage to go get, etc. We may go in the spa again later. Got me thinking it seems odd to repeat this same cycle again if it is going to be used later; thought that it would be better to do when the spa would not be used anymore today.
    19k gal IG plaster, built '70s, probably resurfaced in '80s-'90s; Blue Haven Hayward filter C4520BHMB (Filbur FC-1275 cartridges); Hayward MaxFlo sp2302 VSP 1.5hp; 6 solar panels 288. sq. ft. total (142"x47.5" ea.) on 1 story hm; Pentair Compool LX220 Solar Controller; FlowVis flow meter; Maytronics Dolphin S200; AG 300 gal AquaTerra spa; TF-100 & Speedstir; gone: Pentair Challenger 3/4 HP 1 speed; Polaris 280
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    Yep, it's your thread you can do what you want!
    Mu tub is bleach, not bromine. I add bleach after every soak, no use trying to remember stuff or letting it cook in there longer than necessary. If I am pretty sure I'll be back in soon I might go a little lighter. Conversely, if I know I won't be in for a day or two I'll add a little extra. Plus, with CYA buffering the chlorine harshness I can never really tell when I get it a little too high anyway.
