Thread: cloudy water - need some help
    I have a 11.5K in ground pool with DE filter. Been using the BBB method. I've had very clear water but recently had some algae show up due to low chlorine.
    my numbers were
    FC 1
    CC .5
    Ph 7.8
    TA 130
    CH 375
    CYA 50
    put in 10 oz of MA and then put in 360 oz of 8.25 bleach to get to shock level
    tested tonight and have
    FC 20
    CC .5
    PH 7.5
    TA 130
    CH 375
    CYA 50
    water is now cloudy. I suppose it could be dead algae. should I just keep running the pump/filter overnight and then test in the morning?
    Thanks for help.
    38,345
    Re: cloudy water - need some help
    Yes. You should continue to run the pump and maintain SLAM level chlorine until you pass the 3 criteria to stop.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    +1
    Just keep pounding it, and things will clear up.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Brush, filter, bleach, time. It'll clear. If you have a sand filter, it could take a while to get sparkling again. There's a how-to article in Pool School that tells how to add DE to a sand filter.
    May 2013
    mid-TN
    102
    you might also study this method too.
    http://www.troublefreepool.com/threa...ol-Why-and-How
    it may help keep it clean of algae in the future.
    18X36 Grecian 24400 est., pacfab sand Triton II, 1.5hp AOSmith, clormatic 2
    38,345
    borates should be the last thing on dcar00's mind ... completely optional and unnecessary if chlorine is maintained.
