Thread: Haviland Premium Pool Hose on Pump Outlet
    Mar 2014
    Central AL
    59
    Is this hose okay for a temporary hookup on the outlet side of a pump? A few days at most. I want to test my new pump (Pentair #304204 Dynamo 1 hp 2 speed) without waiting to set up the PVC connections. I've got about 15 psi on the existing 1.5 hp Dynamo, but cant find a pressure rating for the hose. I've got a really thick wall tubing on the pump outlet right now that is just too stiff.
    Russ
    33' diameter, 25,000 gal Above Ground Pool
    Pentair Dynamo 1.0 hp, 2 speed pump (#340204)
    Pentair Sand Dollar 60 filter
    30,432
    Re: Haviland Premium Pool Hose on Pump Outlet
    The hose can probably stand the psi, but I have no idea how to make the connections.....they're probably gonna' blow off.
    Aug 2010
    Atlanta, GA
    39
    I'm gong to venture a no. the connection point on the hose itself is the weak point. It may work but also the pump connection will be an issue. Are you connection to the return side? Maybe a threaded pvc with a discharge hose and metal band clamps? If its the suction side don't do it.
    40x20 Vinyl Inground (27,000 gal). SWG with Pentair 48 DE Filter.
    Also have a broken Polaris pump with no polaris and a broken AquaCal Heat Pump...inherited from last owner.
