Thread: air in the pipes ??
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    air in the pipes ??
    so over the last 36hrs I heated up the pool & the spa (in anticipation of a party today) & had the main pump running almost the entire time
    the main pump was at 2500-3000rpm , usually on the low side of that range
    I also had the heater running for probably at least 16hrs
    so after all the kiddos had left & turned the spa off & returned the pump to "pool" mode to just filter for a couple hours
    when I did this I noticed some air bubbles coming out of the return lines & some air "cavitation" noise from the pump so
    I turned everything off & checked the skimmer baskets & main pump basket
    there was nothing too unusual except one of the skimmers was not seated al the way down & a toy was blocking most of the flow
    I removed the tow reseated the basket & cleaned all 3 baskets & fired the pump back up & purged air at the the top of the filter
    It never really eliminated all of the air & I kept getting surges of air through the system so after messing with the pump valves for the 2 skimmers & main pool drain
    I think I've determined that one (A)skimmer is generating a significantly greater amount of suction than the other (B)skimmer & even when I shut skimmer A off & reduce
    the flow from the main drain skimmer B barely seems t0 generate much suction
    so is this normal to have such a significant disparity between the two skimmers ? could skimmer B be clogged ? is there a design flaw ?
    could there some toy or other mystery time that got past the skimmer baskets clogging a pipe ?
    do I need to call the pool builder ? am I overreacting ???
    (we still owe PB the last 10% + a little more $$ because of post build landscaping issues with the neighbors & problems with his his contractor etc. , it's been frustrating trying to wrap this up ;
    I hate to open a can of worms if we're knee-jerking about this)
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: air in the pipes ??
    It depends. If one skimmer has a lot more pipe and/or fittings it could have much more head loss. But what is the filter pressure for each skimmer and the main drain solo and all three on?
    Mark
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by mas985 View Post
    I know at start up with all 3 returns it was just under 20psi at around 2800rpm
    I should have time to check each return tomorrow .....
    30,408
    With the pump running, are you sucking in air in the skimmers......your water could be too low.
