Results 1 to 18 of 18
Thread: slime on the pool cleaner hose ?!?
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    so I'm getting slime on the pool cleaner hose
    I remember from years ago when I had a blue&white Polaris280 that was a bad sign (algae?)
    the hose with the Racer is dark grey so hard to tell what it is
    any thoughts ??
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    Casey's Avatar
    SW PA
    10,457
    Re: slime on the pool cleaner hose ?!?
    Well, what does your water look like? Are you leaving the hose in the pool for long periods of time? How about some test results?
    Usually a good sign of inadequate fc for your cya.
    Support the site
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    I'm off to buy a Taylor kit today ....
    Make sure to get an FAS-DPD kit. The link in my signature is a good place to get the right test kit.
    Support the site
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by JamesW View Post
    well I'm a newbie & had only seen reference to the Taylor K-2600 previously , wish I had read about the TF-100 sooner
    this is what I ordered , not sure if it's a K2600c but it does mention FAS-DPD
    http://www.amazon.com/dp/B0002IXIIG/..._M3T1_ST1_dp_1
    I found this kit comparo , http://www.troublefreepool.com/conte...its-comparison
    hoping I didn't make a mistake with the Taylor
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Quote Originally Posted by cnatra View Post
    www.amazon.com/dp/B0002IXIIG/ref=pe_385040_30332190_TE_3p_M3T1_ST1_dp_1
    I found this kit comparo , www.troublefreepool.com/content/124-pool-test-kits-comparison
    That is the correct kit. You can buy refills from tftestkits but they won't fit in the nifty little box.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You did not, and the TF-100 uses the exact same Taylor reagents.
    Essential Links:
    Mar 2014
    Thomson GA
    166
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    OK , great
    the Taylor arrived today , did a quick CYA test before it got dark
    (I think I have 0 CYA , no clouding of the water)
    plan on doing all the tests in the morning
    the chlorine test is a little more involved than I expected
    Casey's Avatar
    SW PA
    10,457
    You can collect water from the pool and take it in the house to test it.
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by Casey View Post
    yeah , after watching a few youtube videos that finally occurred to me duh , LoL
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by gwc View Post
    Finally got my taylor 2006 & learned how to use it tonight
    FC 1.4
    CC 1.0
    PH 8+
    TA 220
    CH 80
    CYA 0.0
    I would start by lowering the pH to 7.2 and then get the fc up to about 5 to 10 ppm with liquid chlorine. Then get the cyanuric acid started. Begin working down the TA. Once the TA is down, begin raising the calcium.
    You're showing some CCs, but I think that that's possibly test error. Recheck fc and cc when the fc is about 5 ppm. The slime and cc level indicate that a slam is needed. If the cc is still above 0.5 or you don't pass the overnight chlorine loss test, then begin the slam.
    Brush the pool daily and keep the pH in in the correct range.
    Support the site
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Thanks , going to start slamming today
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    I'm thinking maybe I don't need to SLAM ......
    http://www.troublefreepool.com/threa...sted-the-water
    As long as you pass the overnight chlorine loss test, and have no CCs, then you're good. However, if you don't pass the overnight chlorine loss test, or if you have CCs, then a Slam is indicated.
    Also, due to the slime, I would maintain the chlorine at about 15 percent of the cyanuric acid level for about a week to be safe.
    Support the site
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    OK , Thx
