Thread: Should I even mess with this heater?
    tbone2's Avatar
    Apr 2014
    Hinckley, IL
    14
    Looking for some input on whether or not I should even try to use my heater. Some back ground on the pool heater. Purchased the house as a foreclosure and this has sit at minimum of 3 years without use. Considering the plumbing doesn't even run to it, I presume it may not have been used for 5 years plus.
    The heater is a Raypak model C-265B-MN, 198k BTU's. There are links below to photos to give you an idea of condition. I'm handy and could replace parts if needed, but don't really know where to begin with this (looking online right now for manual or any info from manufacturer). Familiar with pool pump and filter equipment, but this would be my first time dealing with any pool heater.
    If I were to get it working, I only anticipate we would fire it up for 3-4 times in the spring or fall to go swimming. So with that said, would it even be worth any time or money to get it going? I know the cost of a new heater and it's not worth the cost for me to do new for the amount we would use it. If I could get it going and replace any parts for say $200-$400 I would probably be open to it.
    https://drive.google.com/file/d/0B4q...it?usp=sharing
    18'x35' inground vinyl. ~26k Gallons
    1HP Hayward Super Pump. Jacuzzi 250L sand filter. No additional water features.
    Foreclosure pool, 3 years no use. Yes, that is a bike I got from the bottom.
    TFT-100 Test Kit
    Re: Should I even mess with this heater?
    That does not look promising. If the previous owner didn't even have it plumbed in, it probably leaks internally. Plus, from what I can see in the photos, odds are good that many of the other components have either already failed or will fail soon. Certainly it would still be possible to get it working, but it might involve replacing nearly everything. Unless you are into restoration projects, I would think about getting a new heater.
    tbone2's Avatar
    Apr 2014
    Hinckley, IL
    14
    I figured there had to be a reason it wasn't hooked up. Didn't think about the leaking. Just found the info on the Raypak site on the heater and I'm gonna pass on even messing with it. They list it as obsolete actually. If it needed a complete rebuild the parts I was looking at would cost 60-70% of just getting a new one.
    Not in the market now to get a new one, but how many BTU's do you think I would need for 26k gallons? You never know when you could come across a good deal and would at least like to know what range of BTU's would be adequate for my pool.
    TFT-100 Test Kit
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Wow that's an old one. If they had a pool heater museum they might be interested in it.
    The size of a heater depends on how quickly you want to heat the pool. You can go either with a 266K BTU or a 400K BTU unit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
