Thread: maintain borage pool, how?
    Apr 2014
    Sugar Land, Texas, United States
    42
    So I decided to borated my pool, so is that means I no longer require to put trichlor tablet and shock on the weekly basis like I've been doing the last 3 years?
    Also all I have to do is make sure the borage remain between 30 - 50? Do I still need to test pH, ta, and fc? Thanks.
    Re: maintain borage pool, how?
    Welcome to TFP!
    Adding borates is an optional procedure that does not change any of the other things you need to do. You still need to add chlorine, maintain PH, TA, etc.
    Mar 2014
    Thomson GA
    166
    Do you have test results? Your CYA may be high.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by sangweb View Post
    Borates aren't a magic cure-all. You not only need to test everything and adjust it, but you've added one more test! Borates have a mild algaecide function, and they slow the pH shifts, and they make the water feel better against the skin, but they are no substitute for regular maintenance.
    I suggest you spend a few hours - make that days - reading until you feel like
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    Read up and then test your CYA
    And be prepared to freak out
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
