Thread: How much clorine 12.5% bleach 'typically' needed to maintain my 25,000 gallon pool?
    Apr 2014
    Franklin, WI
    1
    NEWBIE ALERT! I've had my money pond since 2000 and want to stock up at Menards when it goes on sale. I know all sorts of things can affect the pool water; i.e., weather, sun, bather load (which is unfortunately not much these days). I live in the Franklin (Milwaukee, WI) area and plan on having pool open from May 16th through September 30 (about 18 weeks). Just would like a guestimate so I can stock up and save some $. THANK YOU SO!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How much clorine 12.5% bleach 'typically' needed to maintain my 25,000 gallon poo
    Welcome to TFP!
    You can guesstimate by figuring out how much it will take to add 3ppm per day to your pool. You'll need your pool volume to do the calculation though.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    I'm certainly a bit warmer in Texas. At 23K gallons using 8%, my usage is about 3-4 gallons/week in summer, 2-3 in winter (no closing for us). That maintains pool at about 6-10 PPM FC.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
