I'm about to upgrade my Aqualink RS ver. N with iAqualink ver. R along with a pump switch to Intelliflo VS. I've done enough research to know that this combination will work fine with no Intellicom required. My question is; do I wire the pump power to the relay (as is the case with my current single speed WhisperFlo) as Jandy recommends, or directly to the breaker panel as Pentair recommends.
I know the Aqualink will control the pump. But will it shut it down to let the valves rotate when I switch pool to/from spa if I wire it hot?
Thanks in advance!
Ron Jenson
Houston
18k gallon pool w/spa by David Perry
All Pentair except Aqualink and Polaris
Thanks in advance!
Ron Jenson
Houston
