Thread: Pool not level
    Apr 2014
    Arkansas
    1
    Pool not level
    The sand under my pool is not level anymore. How can I fix it?
    Casey's Avatar
    SW PA
    10,450
    Re: Pool not level
    The only way to fix the sand under an existing pool is to remove the pool, re-grade the sand and reassemble the pool.
    Welcome to TFP!
    Mar 2014
    Thomson GA
    166
    Re: Pool not level
    What type of pool do you have? It helps people to help you when they know the type of equipment you have. Go to settings next to My Profile and select edit signature.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
