Thread: Are these Ph meters reliable and alternative to test strips?
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Are these Ph meters reliable and alternative to test strips?
    The first one is not a ph meter.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    38,275
    And the drop based tests are generally better than digital testers, unless you spend a lot of money and calibrate often and even then you do not know if the results are good
    I am curious why is that ? is there any digital system that is reliable enough for Ph testing ? Thanks
    There are a couple of PH meters, all over $100, that work fine when properly calibrated. They need to be calibrated frequently, preferably weekly, but at least monthly, with reference solutions. Some of the even more expensive versions can go longer between calibrations, but still need to be calibrated occasionally. The added complexity of calibration makes them much more appropriate for professionals than home use.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by JasonLion View Post
    Agreed, but weekly at minimum.
    I don't know about those but If I were considering one, I would look at a MyronL pH pen. Most like that are not accurate enough for my taste. You will have to get pH buffers/cal solution too don't forget. Its essential. 4, 7, and 10.
    Essential Links:
