Thread: Need info on Intex 16x32 rect pool
    Apr 2014
    Tulsa
    5
    We ordered the Intex 16'x32' pool a couple of weeks ago. It arrived quickly, but without a frame. Had to return and reorder a second one but I can't finish the pad work without knowing the spacing between the supports on the sides and the ends to place pavers. Can't find those measurements anywhere. Hope someone can help.
    A/G Intex 16x32 Rect 14.4k gals. 2650gph Sand Filter
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Need info on Intex 16x32 rect pool
    Hi there, and Welcome...
    This website will tell you all you need to know....
    http://www.poolproducts.com/SPP/dept.asp?dept_id=3086
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Apr 2014
    Tulsa
    5
    Hey! Thanks for the welcome. I've seen that and unless I'm missing something it only gives lengths and widths overall but not the distance between the supports. I'm putting down individual blocks under the supports so I need those measurements to accurately locate them. I've even contacted Intex cust service and they didn't have those numbers either, but thanks anyway.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Bummer, if the company can't help you... I would wait till the frame gets here.... This pool weighs about 17 tonnes when its full of water, that's really heavy, so you want to be accurate on paver location... I'm having artificial turf put under my pool, so I have to cut holes in the turf to get the pavers level with the turf, so I feel your pain... I'm actually thinking about using thick planks of wood to go under the legs...
    Check out this guys thread, its the exact same pool we have.... I'm using this as a reference...
    http://www.troublefreepool.com/threa...a-Frame-UPDATE
    Apr 2014
    new mexico
    1
    exterior dimensions are 17'10" x 34' hope this helps
