From your first link:
Bold added for emphasis. You MUST maintain the FC at or above SLAM level, letting it drop below will only make the process take longer.
Like I said before, your FC is dropping too low and ideally you should be testing and adding more often.
2. Add enough chlorine to bring FC up to shock level (or a little higher)
3. Repeat steps 1 and 2 as frequently as practical, but not more than once per hour, and not less than twice a day, until:
CC is 0.5 or lower;
You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
And the water is clear.
Chlorine additions should be frequent, especially at the beginning. Algae and other organic debris will consume chlorine very rapidly at first. As things progress, you will lose less chlorine each cycle and can add more less frequently.
