Thread: Jersey Pool
    Jersey Pool
    So...my back yard was originally tree lot and a little below grade, although the township says the swale was to the right through other owners yards to the woods. In reality, I had a small wooded pond when it rained. I had a topographic survey performed. The neighbors were irascible by my pool oasis retreat. After all, the previous property owners were here for 10 years and tree lot provided privacy for them and a place to blow leaves from their yard, but, my theory and vision of property improvement will prevail! My liner salt pool is 3.5" above grade as you will tell from the photos. Instead of backfilling with stone, I used fill dirt that compacted to 95 PSI. Twenty four tandem truck loads of dirt were brought in and I waited 4 months for compaction prior to concrete surround pour. Here are some pics:
    Re: Jersey Pool
    I want
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    38,521
    Re: Jersey Pool
    You are not going to be able to continue to attach your photos like that. You need to host them as described here: http://www.troublefreepool.com/threa...oto-s-Tutorial
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Jersey Pool
    Also. Stop making me reach for my thesaurus with words like "irascible."
    Isolated Spa - 345 Gallons
    38,521
    Re: Jersey Pool
    Quote Originally Posted by JVTrain View Post
    I had to look it up too
