Results 1 to 7 of 7
Thread: New House, New AGP set-up
    Jun 2012
    Topeka, KS
    26
    Hi folks,
    First off, thanks for being the best group of pool enthusiasts around. So much knowledge in these forums that help out so much.
    Ok, so we finally bought a house and I'm ready to install a 15' Intex metal frame pool. We've had this pool for three years now, and it's still working great for us. I've put this pool up at two different locations, but it has been un-level both times. This time, I'm going to start early and take my time to do things right. Here is my game plan, so help me out:
    Call to get utilities marked
    Rent a sod cutter and take out about 4-6 inches to get down to hard ground
    Use a level to get the ground completely level (transit level maybe? Has anyone used one for this?)
    Get 1 inch extruded foam and make a 16' X 16' square. I plan to use gorilla tape to make sure it is tightly fitted
    Set up pool and check for level. (put 2 inches of water in the pool and check for level
    Should I use patio blocks under the legs for added support? (if so, do I install level with the ground?)
    Back fill with mulch to hide all the foam and legs
    Am I on the right track at least? As always, suggestions are encouraged to avoid mistakes.
    -Chris
    Intex 15' X 48'' Metal Frame ~5,000 gallons
    2,650 gph Intex Sand Filter
    Hayward wide mouth skimmer
    BBB and Borated
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: New House, New AGP set-up
    Quote Originally Posted by PoolGuy87 View Post
    Hi folks,
    -Chris
    Thank you for the kudos!
    Sod cutter -- Excellent idea. should help with most root problems down the road.
    Leveling -- Cheapest is a length of clear poly tube filled most of the way with water. Next is the 2x4 and 4ft level. Or you can rent a laser level. All three methods would be good enough.
    Extruded foam -- This will go a long way to keeping a good flat base for your pool.
    Patio blocks -- Yes. Top of the blocks should be level with the top of your extruded foam.
    All in all, yes, you are on the right track for a semi-permanent install.
    Good luck! And pease do post pics of your progress, you know how we thrive on those, even for an Intex install!
    Jun 2012
    Topeka, KS
    26
    Thanks Charlie.
    For the patio blocks, should I just use 1' X 1' cement pavers? Is there an easy way to dig and install these? It sounds like a pain in the rear to dig all of these correctly. Last year I think the pool legs sat on the foam, so should I cut the foam to accommodate these?
    Anybody ever used pavers with the pink extruded foam?
    BBB and Borated
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I have pavers but no foam. I'm pretty sure they're the 12" just plain grey squares. Once the ground was level we just placed the pavers flat on the dirt. We used sand though so the pavers are on the dirt and the sand is in the middle. I didn't know about this forum back then.
    It would be awesome to have foam! Our pool bottom has all sorts divots and crevices in it. All lovely places for stuff to gather in but there's no way I'm taking it down again! lol
    It's also been quite a few years since we did it and I can't even see most of the pavers. I don't think they have sunken or anything because the pool is still level. It's just that we had to dig quite a bit and never finished the edges so it's washed out and covered most of the pavers...on the side we didn't have to dig they're kinda covered with grass.
    Been thinking about making it "prettier" this year with some sort of border...we'll see.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Mar 2014
    Thomson GA
    166
    Ditto Charlie_R
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    You can get smaller, rectangular blocks for the legs to rest on. Use a drain spade to dig out those areas.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    A plate compactor will make things easier for you when levelling..... I have a landscaper across the road and he's gonna grab his from his workshop for me... I'm not doing anymore by hand...lol.....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
