Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Liner Leaking
    Mar 2014
    Central AL
    59
    Liner Leaking
    I discovered that my liner is leaking. It's under the skimmer and the previous owner had laid out a path of flat cinder blocks leading up to the skimmer area and hidden the leak. There is a patch on the liner where it is leaking and several other patches in other areas of the pool. It's dripping about 2 drips per second. I cant tell that the other patches are leaking, but this one had made a significant puddle under the blocks. The liner is probably 8-9 years old. Pictures are below. There is a fair amount of rust on the bottom ring, but it still seems sound. I dont seem to be losing a lot of water as far as depth goes, but it is a large pool. Any recommendations?
    Wishing I had gotten a pool inspection before we bought the house....
    Russ
    33' diameter, 25,000 gal Above Ground Pool
    Pentair Dynamo 1.0 hp, 2 speed pump (#340204)
    Pentair Sand Dollar 60 filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Liner Leaking
    Maybe you could try and patch over the patch that's leaking with a bigger patch. Not sure if that would work.
    If it were my pool and given the age, I would be thinking a new liner may be the route to go.
    Someone else may have a better idea.
    Jeff
    Mar 2014
    Central AL
    59
    Re: Liner Leaking
    Quote Originally Posted by pwrstrk View Post
    How do the patches work? Can you apply them underwater?
    I think a new liner would be best also. What are we talking here, $2000-$3000 to get it replaced?
    All that TFP water that would have to get dumped....
    Russ
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Liner Leaking
    Quote Originally Posted by RussH View Post
    Russ
    Yes you can apply them under water, although I've never had to patch one. Check out YouTube.
    You can do the liner yourself with some help from friends if you think that's an option.
    I'd shop around online for a new one if you go that route. Just make sure you don't skimp on it and get the thickest you can. At least a 25 mil liner.
    Jeff
    May 2008
    Long Island, NY
    151
    Re: Liner Leaking
    Patches can be applied underwater. I have had to do a few on my liner. Its not easy, you will need to hold it in place while the glue sets. The edge of the patch has a tendency to curl.
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
    Mar 2014
    Central AL
    59
    Re: Liner Leaking
    I dont mind trying to install a liner, but would probably opt to get it done. At least until I see how much someone wants to do it.
    How long do the patches take to set?
    Russ
    Casey's Avatar
    SW PA
    10,421
    Re: Liner Leaking
    They don't take long to set Russ. When I get a hole, I'd have my son help by holding me under water with his foot. When you're holding g your breath, you have a tendency to float to the surface. I'd suggest someone you trust.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Liner Leaking
    cant remember who but just a few days ago someone else had AGP liner quoted. 3 to 4 hundred for a liner and 7 hunred for the pool people to install it.
    Divin Dave,
    Mar 2014
    Central AL
    59
    Re: Liner Leaking
    Quote Originally Posted by Casey View Post
    I guess we'll try to patch it this weekend. I'll have to go to the pool store to get the patches.... The water isnt really that warm either, low 60's. This will be fun!
    Russ
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Liner Leaking
    OMG That's cold! You need a wetsuit!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Mar 2014
    Thomson GA
    166
    Re: Liner Leaking
    Good luck with the patch. May it hold a long time.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Liner Leaking
    I'm more for avoiding all problems that could come with a patch... You should be able to pick up a liner pretty cheap, especially in the US, they're reasonably priced here in Australia... And just think how pretty your pool will look... There's heaps of youtube vids showing how to replace all kinds of liners..... Hope what ever solution you choose is successful...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mar 2014
    Central AL
    59
    Re: Liner Leaking
    I got two quotes from different places for $1300 and for $1450 installed. That's a lot but still less than what I thought it would cost. Both are 20 mil liners. One was a Merlin liner and the other was an Imperial Vinyl Works. I dont know if I will bother trying to patch or not. I may get a patch kit this weekend anyway. If the liner matches the pump on this pool, any attempt at working on it causes something to physically break (heavy corrosion).
    If I replace the liner, when I refill the pool, do I need to SLAM it or just add CYA and get the FC back to the correct level for the CYA?
    Russ
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Liner Leaking
    Russ
    Just adjust it back up to correct levels... You shouldn't need to slam it.... Test it first of course...
    Mar 2014
    Central AL
    59
    Re: Liner Leaking
    Well I found another leak in it. This one is at another patch and has about a two foot long damp spot along the bottom edge of the pool. We got the installers set up Saturday and they said they are working on a two week backlog, so maybe we can get this resolved soon.
    We got in the pool for the first time Sunday afternoon. The water was 68F. The water quality is really great. No smell, tastes like water, doesnt burn the eyes or nose. My wife has very sensitive skin and it didnt bother her at all which is something I was concerned about.
    Having been in the pool now, the bottom is very uneven throughout the pool. The cove is more of a shelf at the edge with the liner sitting on it than an even taper. Did this likely develop over time or was this a really bad install?
    One last picture with its current liner.
    Russ
    Casey's Avatar
    SW PA
    10,421
    Re: Liner Leaking
    Your water looks amazing! If you want to fix the bottom, do it since you'll be replacing the liner!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Liner Leaking
    If you do replace the liner I would consider getting the foam coving. I have it and recommend it.
    Jeff
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Liner Leaking
    Sparkly water...
    Mar 2014
    Central AL
    59
    Re: Liner Leaking
    Thanks for the water compliments. So far, the water quality is the only thing that has been trouble free with the pool. After the liner, we should be in good shape as most everything has been repaired or replaced.
    Russ
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,421
    Re: Liner Leaking
    Good luck with the liner change! Are you going with a plain liner or a more decorative one?
