Thread: Leaking Pump Housing
    Jun 2012
    Louisiana
    47
    I've tracked down my leak on my water pump to the pump housing. It's leaking between the plate that attaches to the motor and the rest of pump housing. I did notice when taking it apart that the threaded hole on that bottom side (where the leak is) felt stripped. I tried to use some teflon tape, but that doesn't seem to help at all.
    Is all hope lost, or could some silicone get me some more life on this pump?
    25,000 gal Plaster; Hayward 1 hp Super II; Hayward Vari-Flo XL Filter
    May 2008
    Long Island, NY
    151
    Re: Leaking Pump Housing
    is it leaking from a drain plug in the housing or between the oumo and motor? ISounds like your mechanical seal is bad if its leaking from between the pump and motor.
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    All hope is not lost. There is a way to repair the threads. It's called Helicoil Inserts. You get the kit in the proper thread and bolt size, usually from an auto parts store like NAPA or other major brand. McMaster-Carr should also have them, online.
    It will require drilling out the old threads to the recommended size as shown in the kit, rethreading the hole for the thread coil, inserting the coil, and put in a new screw.
    Word of caution: Don't fall over when you see the price of a good quality kit with the special tap. These do get a bit pricey. It does beat buying a new wet end.
    May 2008
    Long Island, NY
    151
    What threads are stripped? Drain plug, housing bolt?
    Hayward makes a housing repair kit. Google sp1600tap
    Its for a SuperPump, I dont know if it will work with a SuperPump II.
    SWG: Circupool Si45
    Jun 2012
    Louisiana
    47
    After my post, I took a trip to the local hardware store to buy a new seal; that solved the problem. Glad it was that simple.
