Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Construction starts tomorrow
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    We previously owned a 24' by 52" AGP and a tree fell on it and compromised the integrity of the wall. We chose to demolish it and upgrade to a larger pool instead which will be a 30' by 54" AGP. It's roughly 9000 more gallons so we are pretty excited. I'll be posting pictures of the install tomorrow along with size comparison pics from the 24 to the new pool.
    30' by 54 Above Ground Pool 22000 Gallons
    1.5HP 2-Speed Hayward Powerflo Matrix Pump
    24' 300lb Hayward Sand Filter
    TF100 Test Kit
    Youngest Pool Enthusiast(Hopefully)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Construction starts tomorrow
    Good luck and I'll be looking forward to the pic's !
    Jeff
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Sorry about the delay guys, construction actually starts tomorrow. They delayed it by two days.. I'm so impatient!
    TF100 Test Kit
    Casey's Avatar
    SW PA
    10,427
    So today is the big day... I expect to see pics by the time I get to work (7pm) so I can loaf around all night reading about your exciting day AND get paid to do it!
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Casey Casey Casey, that's why I love you! Thank you for having such hospitality!
    TF100 Test Kit
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    The pool install has been delayed by the installers until further notice We purchased the pool over a month ago and we have had over 6 delays on scheduled installations. Reason for delays include weather. It's been raining like every 2-3 days. Is rain a huge problem with it comes to installing above ground pools?
    TF100 Test Kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Its slowed my efforts considerably... We've been having heaps of rain here too, and its unfortunately part of the construction process.... Hang in there, it will happen....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Weather is an issue. I am in the 9th moth of my build and we just palstered. hang in there
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Thank you guys. I appreciate your positive words. I called and it isn't supposed to rain here until Tuesday. So it will have 2 days of sunlight to dry out until Monday which is when I found out they are going to install it.
    TF100 Test Kit
    Casey's Avatar
    SW PA
    10,427
    Now what am I going to do all night?!
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Amuse me :P
    TF100 Test Kit
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    This thing is a MONSTER. Casey, we did decide to cut the panel to fit the wide-mouth skimmer. It fit PERFECTLY. Can't believe we actually cut a standard skimmer wall into a wide-mouthed one!
    Leveling:
    Pool by returntohangar57, on Flickr
    Wall Construction:
    Liner goes in:
    Skimmer cut:
    Plumbing:
    Top Rails:
    All Done:
    TF100 Test Kit
    Casey's Avatar
    SW PA
    10,427
    The pool is huge!!! Watch that skimmer box. They are notorious for leaking out the bottom. I hope you don't find out but if you do, get another gasket and sandwich it up against the first one on the outside of the pool and reinstall the skimmer. It was the only way I got mine to stop leaking!
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    They sealed it with silicone. They did a really good job on the whole install.
    TF100 Test Kit
    Casey's Avatar
    SW PA
    10,427
    Is the pool full yet? You have a lot of trees around! If I could have fit a 30ft'er in my yard, I would have!
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    It's about halfway. I'll post a walkaround video of the entire pool when it's filled. I had even more trees, but we had alot cut down prior to this install. It gets ALOT of sun!
    TF100 Test Kit
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Guess what! When the tree fell on our old pool it also landed on our brand new pump I had just bought to replace the old one that was on the old pool. The pump didn't look damaged so we hooked it up to our new pool as you can see in the picture. I turned it on low and it works perfectly. I then turned it on high and it sounded like a dying motor.
    It sounded like it was giving out and barely chugged along. So it's busted. I have a replacement one coming in a few days I'll take the video then.
    TF100 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What pump did you get ?
    Jeff
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    The same one in my sig. It's filled up to the max now. It's a lot deeper than our old one. From 52 to 54 may not seem like a lot but it sure is. Also the skimmer is mounted high so it adds to it being deep.
    TF100 Test Kit
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,427
    Sorry to hear about your pump. Can you just run it on low or is it toast since turning it on high?
