Thread: Losing Salt - Leak??!
    Oct 2013
    Phoenix, AZ
    25
    Now that winter is gone and my salt cell can start producing clorine again I went and had my salt levels test to find out I have well below normal amount. I didn't save the PPM, but added two 40lbs bags of salt last week and tested again. I'm now at 1700 ppm while the recommended is 3400 ppm.
    How do I begin testing for a leak? I shut off the auto-fill four days ago and the water level is about 2 inches below normal. I did notice in my raised spa there are two cracks in the steps, but I just can't image that would be leaking that big. Attached are some pictures of it. Also have notice by the pool skimmer we have grass. That grass by the skimmer grows greener and faster than the other grass...
    Here is link to pictures of the cracks noted. https://plus.google.com/photos/11362...Pf5raau87vHuAE
    Thanks for any tips.
    Size of pool (gallons) = 15,000
    Pool Type: is IG (in ground)
    Construction: Plaster
    Filter type: DE
    Filter Manufacturer: SM/SMBW 2000 Series
    the size, model number or flow rate of the filter.
    Pump in HP = 2
    Pump is two speed
    Date of pool build/install = circa 2001
    with spa
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Have you looked in Pool School ? There is an article about leak detection. For the cracks in the steps would you be able to use some dye to see if the dye gets sucked into the crack ?
    Jeff
    38,268
    Re: Losing Salt - Leak??!
    Also search for the "bucket test" to confirm the water is draining from the pool faster than evaporation (which can be high here).
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If the bucket test confirms, look for the source for the "greener grass". In this case, it's not on the other side of the fence!
    Oct 2013
    Phoenix, AZ
    25
    thank you for the fast responses. I'll research out the leak detection thread and try the bucket method mentioned. I would assume our evaporation rate is high right now, its been pretty hot and dry already.
    I"m going to hold off on adding more salt right now until I do the bucket test.
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
