Results 1 to 11 of 11
Thread: Filter Replacement Sizing Advice Requested
    tschaefges's Avatar
    Jun 2008
    Sidney, IL
    35
    I have a 5-year old 17'x29' rectangular Splash Superpool that holds 15,000 gallons. The dealer included a Sta-Rite Hi-Rate sand filter (P/N JSAL180E-58 also marked T-180WF) and a 1hp Sta-Rite pump (P/N ABG4E-2A4). The plastic base that holds the filter and pump cracked and will need to be replaced. This may be a good time for me to upgrade the filter and I would like some size advice.
    The pool is used almost exclusively for our dogs and their canine friends. It's not uncommon for us to have 6-10 dogs in the pool four or five days a week. I have been able to keep the chemistry in line, but the dogs carry a lot of particulate matter into the pool which often results in cloudy water. It is sometimes a struggle to keep the water as clear as I'd like.
    The sand filter label says it's 1.57 sqft and I am wondering if it would be worth switching to a bigger filter. If so, how big should I go? If I upsize, can I keep the 1hp pump? Is bigger always better, or is there a point of diminishing returns?
    Thanks!
    Tom
    17' x 29.5' x 4' Splash Superpool AGP, 15,000 gal, Hayward S244T sand filter, Sta-Rite ABG4E-2A4BBB 1hp pump, BBB / TF100 test kit
    East-Central Illinois
    38,301
    Re: Filter Replacement Sizing Advice Requested
    For a 15k pool, I would recommend a ~23" sand filter. The bigger filter reduces the frequency of having to backwash. Your existing pump will be fine although should consider a 2-speed motor when you pump eventually dies to save some money on power.
    Cloudy water is generally due to lack of FC ... if you are going to have heavy use, smart to bump up the FC either before or after. Not uncommon to get a little cloudy during heavy use though.
    With all the dog, you should likely use a skimmer sock to keep the hair out of the filter.
    tschaefges's Avatar
    Jun 2008
    Sidney, IL
    35
    Thanks, Jason!
    We always have a sock on the skimmer. It's amazing how much hair it catches, especially when a new dog has been in the pool.
    mas985's Avatar
    Pleasanton, CA
    11,737
    tschaefges,
    How often were you backwashing your current filter?
    Mark
    tschaefges's Avatar
    Jun 2008
    Sidney, IL
    35
    I backwash when the pressure rises 8-10 psi over my clean reading. I'd say on average that's every 10-14 days, sooner if I have added DE to the filter. I should probably track that more closely.
    Tom
    38,301
    We recommend backwashing when the pressure rises 20-25% over the clean pressure, which is probably more often than you were doing. Thus the larger filter I think would make sense in your case.
    mas985's Avatar
    Pleasanton, CA
    11,737
    What is your normal clean filter pressure? I am just trying to scale your current filter.
    Mark
    tschaefges's Avatar
    Jun 2008
    Sidney, IL
    35
    I made a mistake above. My normal clean pressure is 10 psi. I backwash at 13-14 (not 18!).
    mas985's Avatar
    Pleasanton, CA
    11,737
    Can't you just take the filter and pump off the base?
    But if you do replace the filter, doubling the size will more or less double the time between cleaning if that is of interest.
    Mark
    tschaefges's Avatar
    Jun 2008
    Sidney, IL
    35
    I'll have to take the pump off the base, but then I also need to find something to which to mount it and something for the filter to stand on. I'll get another base if I keep the same filter, but I thought this might be a good time to upgrade if it made sense. The dogs carry a lot more stuff into the pool than people do.
    38,301
    You don't need a special stand. Mine are sitting on pavers, others use the plastic air conditioner pads, or pour a cement slab.
