Results 1 to 15 of 15
Thread: new here...getting 16x32 inground..question about chlorine
    Apr 2014
    Stony Brook, NY
    159
    My pb is suggesting the frog system, which I see everyone here hates. So ultimately, im thinking just having a puck feeder put in at first. I figure I could maybe add a stenner or liquidator at a later time. Just wondering what anyone's thoughts are? Btw, he is suggesting a vs pump, so it seems a liquidator wont work well. Are vs pumps worth the extra money?
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: new here...getting 16x32 inground..question about chlorine
    Have you considered a SWG for chlorine production?
    Apr 2014
    Stony Brook, NY
    159
    Quote Originally Posted by YippeeSkippy View Post
    I have thought about it, but thought it might not be worth the extra $1900 he wants to charge.
    38,524
    Welcome to TFP!!!
    Yeah, that is a bit high for a SWG. The SWG should be available under $1000 plus << $100 for salt. And the install is very straightforward when starting from scratch. Although it is pretty easy to retrofit in as well if you just tell him to leave longer sections of straight pipe.
    How high is your electricity cost? Might make more sense for a small 2-speed pump.
    Apr 2014
    Stony Brook, NY
    159
    Welcome to TFP!!!
    We have the 2nd or 3rd highest el rates in the country. The local el company is offering rebate on vs. So it is only costing me additional $150 after rebate. Maybe i should see if i can negotiate dumping the frog, and going with swg for an additional $1k. Thoughts? Im thinking maybe 3 year recoup in chlorine savings???
    38,524
    SWGs generally do not save any $ over adding bleach manually ... they are just more convenient.
    Apr 2014
    Stony Brook, NY
    159
    So for now, would i be better off with just a puck/chlorine setup? I have had them in the past on aboveground pools, and thought they worked fine.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You have to be aware of what the pucks add. They add chlorine along with stabilizer (CYA). Every puck contains CYA. Once that CYA level gets out of range that's when the trouble can start. When the CYA level gets really high you can't keep your FC levels high enough for the CYA level and you have an algae out break. The only way to lower CYA is water replacement. They are also acidic and lower PH.
    You can use pucks in the beginning, you just have to know when to stop using them. For a non SWG pool you want your CYA level to be 30-50 ppm. When you hit that range you'll need to switch over to liquid chlorine.
    I like to suggest for someone new to manually add the stabilizer and use liquid chlorine from the start if your not using a SWG. It's easier that way. By the way for a SWG your CYA level is 70-80 ppm.
    Jeff
    38,524
    Depends .... as long as you understand the CYA/FC relationship and that the pucks are adding CYA continuously and building up, thus requiring higher levels of chlorine, then that is fine. With your shorter season and if you get a fair amount of rain, the pucks might work for you ... not necessarily cheaper in the long run.
    For a SWG you have to spend a lot up front, but then very little for 3-5+ years until you need to replace the cell.
    For bleach/pucks, you are paying less up front, but continuously.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Apr 2014
    Stony Brook, NY
    159
    I am gonna give that a look. From some of the reading i have done, It would cost me about $800 to purchase a good SWG online. My PB wants to charge me almost $2k additional. Sounds ridiculous since he is saving on not using the frog system. You think if I got him down to $1k additional that would be reasonable? Based on what I have read, SWG is a no brainer as far as set it, and forget it.
    38,524
    SWG is not set and forget. You still have to be testing and adjusting the output since chlorine demand is variable.
    Apr 2014
    Stony Brook, NY
    159
    Yes, I kind of stated that wrong. Just meant it seems more user friendly and less to go wrong once set up.
    Apr 2014
    Stony Brook, NY
    159
    Update....pb is giving me SWG for additional $800. So I'm going that route. Thanks for the suggestions!
    Casey's Avatar
    SW PA
    10,461
    Good that you got him to come down and you ditched that frog!
    Apr 2014
    Stony Brook, NY
    159
    Quote Originally Posted by Casey View Post
    He said I would have no issues with the frog, but what I have read, it could have turned out to be a waste of $ in the long wrong, and possible issues also. My fiance was a bit against the SWG since its "the thing to do" around here. Most people around here think there is no chlorine in a SWG pool. Kind of comical.
