Thread: 3 port valve for Suction end and for return lines. Jandy vs Hayward
    Central Connecticut
    159
    I currently have (2) Hayward 3 port valves that need to be replaced. I believe they are the Hayward SPX-733 Dial-a-Flow valves. I am considering replacing them with the Jandy 4715 Neverlube valves. Any thoughts, recommendations or experience with the Jandy 4715 valves?
    Thanks
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Re: 3 port valve for Suction end and for return lines. Jandy vs Hayward
    The Jandy Neverlube valves are the best available valve. Hayward and Pentair now have valves that are so close that you are unlikely to ever notice a difference.
    38,515
    Jandy Neverlube are the standard ... Hayward and Pentair also make equivalent valves. Any should be fine.
    What size if you pipe? Better to use the valve size that lets the pipe slip in to the valve. If 1.5" pipe get the 1.5/2 valve, if 2" pipe get the 2/2.5 valve.
    Central Connecticut
    159
    I have the 1.5" lines, so they would slip into the ports. I have to either replace the guts on my Hayward valves @ $38 each, or just plumb new Jandy 4715's for $40-$ 45 ea. Seemed like the Jandy had better reviews and seemed to last longer.
    Thanks jblizzle,
    Rich
