Results 1 to 8 of 8
Thread: Hot Tub Turning on and off
    Apr 2014
    Pa
    4
    I was given a Tiger River Spas hot tub that sat for 2 years. Set it up yesterday ran all the electrics filled with water and plugged it in. The spa turned on and ran for 30 seconds then shut off. No power to the control panel at all. Waited 4 to 5 minutes and plugged it in and did the same thing. Left it plugged in and it was doing it on its own. Turn on for 30 seconds and then no power to the control panel. Can anyone help me out? I do know that the No Fault 6000 heater is leaking and needs replaced. Also the pump motor is loud and vibrating pretty bad. May need to replace that as well.
    Please help!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hot Tub Turning on and off
    You say you plugged it in. It's not tripping a breaker? It's not tripping an outlet or cord integrated GFCI?
    Sounds like the heater and/or the pump is drawing too much amperage and causing a shut down. It could also be that the pump is not detecting proper prime and is shutting down because of that. If the heater is leaking enough, perhaps the pump is not able to establish proper prime.
    Isolated Spa - 345 Gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Do you know what model year it is, also if electronic control box, does it say IQ-2000 or IQ-2020 molded into the plastic cover?
    Apr 2014
    Pa
    4
    Quote Originally Posted by Isaac-1 View Post
    It says IQ-2000!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You might want to take a look at this manual for trouble shooting http://www.hotspring.no/manualer/tig...ers_manual.pdf
    Does your tub have a circulation pump? Or just a Jet pump / pumps?
    Ike
    Apr 2014
    Pa
    4
    It does have a circulation pump.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok, it sounds to me like you have more than one problem.
    Are you getting water circulation, these tubs will shut down on overheat if the circulation pump is not working right, and these circulation pumps are prone to air locks if not primed after sitting empty.
    Ike
    p.s. you may also want to try plugging it in with the cover off the control box and see which of the LED lights are lighting (near the top center / top left of the circuit board) See section I:6 of that manual in the link above
    Apr 2014
    Pa
    4
    Ike
    The circulation pump is turning on! I need to look at it today to see what the lights are. I believe the top 2 are lighting up and it shuts down before the third light comes on. I'm just not sure what the lights are. Thank you for your help.
