Results 1 to 10 of 10
Thread: Weather forecast just changed. Uh Oh!!!
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    They were calling for a low of 28 for a couple hours overnight a few days ago. Other than that no where near freezing in the long range forecast. It just changed. We have a freeze warning overnight. Low of 22 now. I sure hope that pump keeps pumping. Maybe I opened a few days too early. We actually have flurries coming down now.
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    Apr 2014
    Indiana
    106
    Re: Weather forecast just changed. Uh Oh!!!
    I know how you feel... I was working on the pool in only a pair of shorts on Saturday because it was too hot (80F) - I even got sunburned!
    Last night it started snowing and this morning we had probably nearly an inch of snow! :-/
    I just put the pump on constant but I'm not too concerned about it.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Look at the good side....you'll lose less chlorine when it's cold. Up by us (Steubenville) they're calling for temps in the 50's Wednesday. You'll be fine.
    Feb 2012
    Maryland
    400
    Everything should be fine, not sure you specifics but I would suspect 22 is the low at the worst, I would suspect it will drift down overnight and be below freezing for a few hours then be back up. I don't think it would be enough to freeze anything solid especially if your water is already warm.
    Back in early March I would go out and check my skimmer and it would have some ice skimming on the water about the thickness of a piece of paper.
    If your setup is at all like mine, 99% of the plumbing is well underground. In my particular case, the only real area of concern is my deck jets but even then 99% of those pipes are underground. PVC must have some insulating factor.
    Well, I guess if I would read your signature I would know your specifics!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    30,426
    Those conditions are not enough to worry about......even if the pump stopped.
    Feb 2012
    Maryland
    400
    Curious duraleigh, are you saying a few hours at 22 would not freeze water in the pipes even if it was not moving?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Let me put it this way:
    I didn't bother to turn on my pumps until this morning around 5:30. No problem in starting them, at a temp of 28. It had been below freezing since around 11:30 last night.
    It takes closer to a full day of below freezing temps to freeze the volume of water in 1-1/2" pipes even when fully exposed.
    Apr 2012
    Lynchburg, VA
    90
    In my experience it would take quite a few days of cold(perhaps a week or longer) before you would need to be real concerned.
    of course that is in VA....
    I think you will be ok
    30,426
    Yes...not cold enough long enough.
    Apr 2014
    Indiana
    106
    My water was 55 degrees last night. I think it will be fine for a day.
