Results 1 to 9 of 9
Thread: Best advice for tiny bits
    Apr 2014
    Louisiana
    51
    hey guys, my pool looks pretty good right now at a glance. But if you really inspect the water, there are tiny bits of this and that floating around. I"m talking about like 'specks' of stuff. I'm guessing its pieces of leaves but they don't seem to be filtering out.
    is there a trick to get the tiny stuff?
    will more things filter if I pin the door to the strainer down maybe?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Best advice for tiny bits
    Is this on the surface or mixed in with the water?
    If it's on the surface, the last thing you want is to hold the weir down. The weir accelerates the movement of surface water into the skimmer. If your water level in the pool is too high, you can experience reduced skimming action too.
    Often the solution to surface debris is to work with your returns to get them to guide things that are floating so they run along the pool wall where the skimmer is. Aim them close to the surface so they make a small ripple and direct them to move things around the pool so the skimmer has an opportunity to grab stuff that is floating.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    You will never be able to get 100% of everything out of the water, but you can add some DE filter media to your sand filter to help catch the finer debris. DE comes in 20-25lb boxes so if you have a friend with a DE filter you may want to borrow some first and see if you like the results.
    You add about a cup at a time of DE through the skimmer until you see a 1 point rise in pressure, and run the filter as normal. After back washing you will need to add DE again.
    Love TFP? Become a
    TFP Supporter!
    Apr 2014
    Louisiana
    51
    the debris is mixed in. I use my leaf blower to direct current to the skimmer for top stuff. works pretty well
    where can I buy DE?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Jul 2009
    Houston, Texas
    9,396
    Pool stores, home and garden centers, just about anywhere that sells pool supplies. Just make sure it is pool grade and not insecticide grade DE.
    Love TFP? Become a
    TFP Supporter!
    SW Indiana
    9,199
    How many hours a day are you running the pump?
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    I found a smaller 10 pound box of HTH brand DE online at Ace Hardware for $14, shipped free to my local Ace store for pickup. Might be worth checking out?
    Apr 2014
    Louisiana
    51
    i ran the pump about 6 hours a day all winter. the last 3 days i have been running it non-stop. (except to switch settings and stuff)
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    If you see these things at night, with the pool light on, we call them "floaters." You'll never ever get rid of them all.
    If it's in daylight, adding DE to the filter should help clear them.
