Thread: Opened my pool in CT today. All is good
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    419
    I opened my pool today and all went good- no leaks, no air and moderate leaf junk.
    Water is 52%, but it was frozen just a couple of weeks ago. I actually fell in for the first time testing how thick the ice was - a first for me.
    I try to open early (normally April 1st) as we start using the hot tub and will heat for a weekend if it warms up.
    Will be opening a few more pools this week and next, so now we just need some warm weather.
    Believe it or not I have not covered my pool the past couple of years as I like to keep an eye on the water or ice level - in fact a month or so ago it warned for a couple of days and I drained out another 6 inches of water.
    Anyway we do have some weather left, but I do have freeze protection and a back up generator so I not worried --- but I do think it takes a pretty hard freeze > 20 for a day or two to break a pipe, but that's just my experience.
    Shocking and running pump now and just need to get cleaned up and the water balanced.
    Anyway hope some more people up north and Canada start opening soon. I think its about time....
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Opened my pool in CT today. All is good
    Quote Originally Posted by blakeusa
    Water is 52%...
    If you meant to say that the water temperature is 52F, then you are opening right on schedule . Even if you get hit with an overnight freeze once or twice before it's all said & done, I wouldn't worry about any freeze damage at this point. As you stated, it would take a couple of days of air temps around 20F to get the water to freeze hard enough to risk pipe damage, especially with water temps in the 50's. Even in CT, I think overnight lows in the low 20's are behind you for the season.
    kkpjm's Avatar
    May 2011
    Quakertown PA
    41
    You DON"T cover the pool? Does that mean you are chlorinating all winter (when it's not frozen...)
    20x44x8 Cardinal vinyl IGP, 33000 gal, 2 hp Mustang, 60 SF CrystalWater DE, Zodiac LM3 SWG
