Thread: Pool Pilot Digital - Lock Up
    Mar 2008
    Pelham Alabama (Birmingham)
    For the past few months I have thoroughly enjoyed my newly installed Pool Pilot SWG. But I am having one issue with it. Every so often, maybe once every couple weeks, the Pool Pilot control unit will lock up. Yes, literally lock up. All (vast majority) of the LEDs on the display will show constant on. When the happens, the unit is locked up to the point where the scheduled pump cycle does not work, and the pump remains on. To correct the lock state, I have to restart power to the unit, then it is all normal for a couple weeks. Also, it has always locked up while the pump is ON.
    I've been just kind of going with it until the last weekend, and the unit locked up, and staying in the on state. So my pump probably ran 24hrs for most of the weekend, which I have no real problem with. But with the pump being constant on, and the SWG chlorine generator also being on, my pool has an inflated chlorine ppm. Not overly high, about 12.5, but I see where this my be hazardous if I was attentive for a longer period of time.
    Ideas on how to prevent the lockups?? I may need to call the manufacturer, but I thought I'd try here first.
    Mister Mister
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
    Hayward S244 Sand Filter
    Hayward 1hp RS1000 Pump
    Leisure Bay Spa - Flores - 500 Gallons
    AutoPilot SpaPilot - Not Yet Installed
    Re: Pool Pilot Digital - Lock Up
    It sounds like your unit is defective and need service.
