Thread: Need advice with putting up a new salt water AG pool in yard
    Jul 2012
    Hicksville, NY
    18
    Ok so last 2 years we had up a 12' round pool and used bleach and borax to maintain. I felt like the pool was a 2nd job trying to get the levels right and my kids don't really care for chlorine, so I am thinking of buying a new rectangle pool 18' x 10' x 52" and using salt water and a SWG and the sand filter I bought. How do I go about starting? Do you just put the salt in and let the filter and SWG do the work? Do I need other chemicals to maintain a SW pool?
    Thanks
    Angelique
    Hicksville, NY
    4,500 18' x 9' x 52" Rectangle Intex
    Above Ground Vinyl Pool
    Intex Krystal Clear 2,800-Gallon Gallon Sand Filter
    Intex Salt-Chlorine Generator
    Sep 2013
    Terre Haute, IN
    36
    Re: Need advice with putting up a new salt water AG pool in yard
    Not trying to be insulting here but want to be sure...
    You do know that a SWG is a Salt-Water CHLORINE Generator?
    You will not be ditching chlorine by going to one.
    33,000 gal Inground Vinyl Liner
    Hayward Sand Filter
    2 skimmers
    2 returns
    1 vacuum line
    1 main drain
    Using a SWCG will only change your method of dosing chlorine. Everything else would remain the same.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
