Thread: Muriatic Acid Does temperature affect it?
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    On Saturday my TA was 230 and my PH was 7.5. I decided to go ahead and put in 32 oz of muriatic acid this morning to start the process of bringing the TA down a little. I also turned the return eyeball up to help aerate the water to keep the PH up.
    Last year when I watched a man pour 32 oz in, it was like a steam or smoke rising from the water as it poured. When I put it in this morning, I didn't see anything like that. Then a couple hours later when I tested the TA.....it hadn't changed any.
    Does the colder temperature affect the acid as far as the reaction when it hits the water?
    Wouldn't I have expected a little change in TA?
    I used 28.3% - 18 muriatic acid.
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Muriatic Acid Does temperature affect it?
    When you tested the TA, did you also test the pH? If you did, was there any change to that?
    30,402
    You didn't add enough acid to make any significant difference.
    The correct way to lower TA can be found in an article in Pool School.
    Mar 2007
    San Rafael, CA USA
    12,082
    32 fluid ounces of Muriatic Acid (your 28.3% Hydrochloric Acid) in 18,500 gallons would only lower the TA by 6 ppm so might not be measurable. As Dave noted, you need to follow the Pool School article on how to Lower Total Alkalinity.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Most of what I read said to lower it slowly. I guess maybe I was trying to slowly. I'll check the PH again in the morning to see how it is.
    Quote Originally Posted by brmommy View Post
    That effect is highly dependant on the weather conditions and should not be a basis for assessing the strength of the acid.
    Support the site
