Results 1 to 11 of 11
Thread: What am I forgetting?
    Feb 2014
    Pennsylvania
    8
    Total rookie here. I'm still reading and overwhelming myself with the wealth of info on this site, but if you could help me with my checklist, I'd appreciate it. Aside from the building materials, once I get the pool up, what items are must-haves? So far I've bought the 22x52 Intex pool, Intex 2650 sand filter/pump, and the Intex SWG. On my shopping list I have: the Hayward SP1091LX skimmer, Wanda the whale, and the TF-100 test kit. What else do I need? Which winter cover do you recommend? Do I need a solar cover and if so, which one is recommended? TIA!
    Re: What am I forgetting?
    I'm not sure what comes with the Intex kit, so these might already be included. You are going to want a pole, with leaf rake and brush attachments. You will want to have some chlorine (probably bleach) and CYA around for the first couple of days. Other chemicals depend on water test results. You could measure your fill water to see if any other chemicals will be required right off.
    A solar cover is optional. It will help the water warm up in the spring and fall, but is extra work. Some people love them, many people don't bother.
    Get a winter cover sized for your pool with tie downs around the edge and preferably with a rope around the edge of keeping it tight to the pool wall.
    For both covers, don't bother with the more expensive premium covers. They all last about the same amount of time, so the extra money is hardly ever worth it.
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Beer!
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Gonna need some pool noodles and squirt guns and wind=up motor boats, too.
    Butterfly's Avatar
    South Carolina
    10,045
    Salt for the SWG.
    You're done SLAMing when:
    Feb 2014
    Pennsylvania
    8
    Rest assured, my four kids will have no shortage of pool toys and floaties. I need to figure out some way to provide shade over a section of the pool, and find a winter cover (having a hard time locating a 22' winter cover. Would one meant for a 24' pool work?), but then I think I'm set!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You are going to need a skimmer net to scoop stuff floating on top of the water.
    Note: A skimmer net is not the same as a leaf net, a.k.a. leaf rake. Leaf rake is much bigger and is for scooping stuff off the bottom. No doubt, the skimmer net is the most used maintenance thing i have.
    You are going to need a vacuum head and vacuum hose for vacuuming the pool bottom. (the vacuum head will attach to the pool pole jasonlion mentioned) in lieu of the manual vacuum is a automatic or water operated pool cleaner of any varied variety, kreepy krawly, robot polaris or some other similar contraption.
    Probably a backwash hose to divert water away from the immediate vicinity of the sand filter when you backwash.
    Not a must have, but a thermometer might be handy now and then
    You prolly will need some muratic acid to help with Ph when it goes up
    A 1 qt measuring cup for measuring acid, chlorine and other stuff.
    The next ones listed are not an option. They are absolutely essential
    new sunglasses
    goggles for seeing underwater
    a new lounge/ pool chair
    2 new BIG beach towels
    a new swimsuit or 2
    suntan lotion
    new flip flops
    and last but certainly not least;
    a fat wallet !
    Divin Dave,
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Quote Originally Posted by Jenniferx2 View Post
    I need the same, I am light skinned and burn quick. When I had an above ground pool I purchased a cheap patio umbrella, drilled a couple holes in the pool then screwed it to the handrail so it shaded about a 4 foot area, that was my little spot and everyone knew it
    We have a pool house on our current IG and it shades part of the shallow end in the late afternoon.
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    Someone here kept a tub of water (like dish washing tub or a larger mortar mixing tub -- $5 at Home Depot) at the ladder to the pool so kids could get grass and dirt off their feet before they got in the pool. I thought that was clever.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    You have the required kids so, why not an under water camera? I got one for about $80. It's a Nikon and it is absolutely priceless with the kids. I turn my granddaughter loose with it and I get some really good pictures. Then sometimes I take the pictures and I get things like this.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Jul 2012
    Seymour, In
    49
    One big item, that is free that I didn't notice listed in the other replies is patience.
    If things start to get out of whack, you will find all the info and help here on the forums. When you start working to correct those out of whack problems, you will need to have patience. Other then what everyone else has mentioned already, I think you will be set for a great summer of swimming.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
