Thread: Info on OLD Lomart Pool Fillter request
    Hi!
    Would anyone out there have information on a Lomart filter system from approx the mid 1960s-early 1970s? It was a small filter, gold/ bronze colored tank that held paper like accordion-type cartridge, and a light green thing that fit inside as well. This was a small filter for an above ground pool. Any information on model number, specifications, pictures greatly appreciated! Thanks!!!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Info on OLD Lomart Pool Fillter request
    I have a copy of the Unicel filter listing PDF, and it shows 3 model numbers for Lomart filters.
    60-4314 13 sq ft cart 4-3/4" dia x 18" high
    Unicel replacement C-4618
    60-4316 16 sq ft cart 4-3/4" dia x 18" high,
    Unicel replacement C-4601
    60-4318 same as 60-4316
    I hope this helps in your search.
