Thread: Pool Heater Remote Recommendations
    Apr 2013
    East Bethel, MN
    19
    I'll be adding a heater to my pool this spring, a Rheem 400k NG heater. According to the manual, the heater is remote ready but I have no clue which remote would best fit my needs. Rheem sells a remote I could use inside the house but I'd like to have the ability to turn the heater on/off remotely when I'm not home. Turning it on, for instance, when I leave work. I've seen some posts for Jandy, Intermatic, AquaLink, etc. but I'm not sure what would work best or what equipment I need. Anyone have any suggestions? The pump is already set-up on a manual timer and my plan is to run power from the the pump to the heater for the electronic ignition.
    Thanks
    2013 21,500 Gal. 28' Round AB Doughboy
    DE Filter, Taylor K-2006 Test Kit
    Solar & Rheem 400k heat
    Re: Pool Heater Remote Recommendations
    For control from the house all you need is a wire and a switch. For control via the Internet you will need a full automation system with Internet features, or a home automation system with some DIY customization.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by Frank Raff View Post
    Rheem sells a remote I could use inside the house but I'd like to have the ability to turn the heater on/off remotely when I'm not home. Turning it on, for instance, when I leave work. Thanks
    I have never seen or heard of a remote by Rheem for the pool heater. I believe the unit you see is for the tankless house hot water heater. Not sure if this would integrate with the pool heater or not. I'm sure it's just a two wire control. Most people have a control system for the entire pool/spa combo and control it that way. I would look into that Rheem remote more to see if in fact it does work with the pool heaters.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
